Well I had 2 leaks from my transfer case origionally. They were pretty small leaks, with only a drop now and then from the front propeller shaft and the typical parking brake leak.
I searched around locally for new oil seals for the transfer case, and the only place that I could find them was NAPA. They had the front in stock, but had to order the rear. I had them order 2 rear seals in anticipation of installing a dual seal speedo housing from Mudrak.
I took the front seal home, and started what should have been an easy job of replacing it, only to find out (not surprizingly) that it was the wong seal. So I searched around to try to find the right part number for the proper seal, and couldn't get much info on it. So I ordered a transfer case and pinion seal kit from CCOT. It comes with 2 pinion seals, a front propeller shaft seal (these three are actually the same part number) and a rear transfer case seal.
Well, the front seal went great......went right in and no more leak. I figured that since I already had the rear seals from NAPA, that I would install one of those temporarily until I got the dual seal housing, and I would use the better Toyota seals then.
Well heres where the fun begins....of course, I destroyed the origonal seal while removing it. I then test fit one of the NAPA seals on the shaft of the parking brake drum...seems pretty loose to me. The drum has a slight groove, but not bad, and the seal is loose the entire length of the shaft, not just where the groove is.
So, I'm like s***...I'll have to use the Toyota seal, and just order 2 more. The Toyota seal from CCOT is snug on the shaft of the parking brake drum, but the OD is WAY too small, and it won't press in. So I go with the one that I can at least get to press in (the NAPA one), and put everything back together and cross my fingers. I drove around, and only got a couple of drips. But then I parked in my driveway, which is on a slope, with the rear of the FJ facing downward. About an hour later ALL of my gear oil is in my driveway. So, now it's not just a slow drip anymore, and I have no way of fixing it quickly.
Why the fawk is it that no one can give you the proper part
It would be different if they just didn't have it, but when I order the same part from 2 different places, and they are both different, and NEITHER ONE of them is the right one, and one came from a place that specializes in Land Cruisers, and I've had to take this thing apart and reassemble it 3 times, It gets REALLY annoying. Especially when I now have a gallon of 90 wt gear oil all over my driveway.
Is there anyone who knows the proper Toyota part number for the transfer case rear seal in a '73 FJ40 Land Cruiser? Also I need to know the part number for the speedi sleeve, since I might as well do that while its apart.
