Random questions
SoCal
1. Engine is out. Rear motor mounts look like they should be replaced. The fronts are more difficult for me, an absolute rookie, to evaluate. Should I just get new ones? They're available?
2. Bell housing was attached to engine w/ 12-point allen bolts. Is that an OEM fastener for that application?
Vic
Redlands, CA.
Vic
Redlands, CA.
What are you working on:confused:
can't hurt to replace motor mounts, might as well do all 4.
torques(sp) are not oem fasteners. bellhousing bolts are "just" regular hex bolts. that's assuming you're dealing with a 40 or atleast a 60.
Yes they are available, and if the rears are in poor condition it is likely that the fronts are also...
This is a fastener used by VW for head bolts and the like, known as a "triple-square" internal drive fastener. They are not stock Toyota. You may have had fun removing them, as that is not a common socket at tool stores..
Good luck!
-Steve
Sorry, good point about what vintage. '74 body on a '72 frame. Steve is right, 12-point, and metric, allen, not a Torx. Thank God a buddy owns an independent Benz/BMW shop and has every tool imaginable! Oh, and that he lets me borrow them. I'll 86 the allen bolts, get new motor mounts.
Oh, almost forgot. What is the length of the bolt to join the bell housing to the block? 1 1/2" of thread sufficient?
Thanks guys for the invaluable help. It'd be like swimming in the middle of the Pacific without having your experience to keep me headed in the right direction. In other words, if I screw up it's your fault, not mine. Damn, that sounds good. I might run for some elected office or other.
Vic
I would try and find a fastener that 40-45mm in length, from the inside of the head to the end of the threads...
Sounds like you would fit right in out there in the political sceene in the peoples republik of kalifonia....
Good luck!
-Steve
IIRC, Toyota upgraded the motor mounts from what came OEM which were kinda prone to come apart. At least on 2F FJ40s. Another good reason to change the fronts, too.
-Steve
Steve, if you only knew!;p
Vic, surprised you didn't mention this earlier today.:confused:
New motor mounts are VERY cheap insurance. Ask Nolen.;)
[Vic, surprised you didn't mention this earlier today.:confused:
New motor mounts are VERY cheap insurance. Ask Nolen.;)[/quote]
Uh, well, yes. I think getting myself lost when I was w/in one block of your place had something to do with it. I'm making a list next time.
V
