Random part rattled off my 80
Wherever the money is!
Hey all, I put new u joints in my front shaft this weekend and also pulled the starter for new contacts. When I pulled my rig out of the garage I heard about a 30 second rattle then went quiet and when I came home I noticed this part laying in the driveway. It looks like a small heat shield but I can't find anything it could go to. Anyone have any ideas? Rig runs and drives fine with no weird vibrations or noises. Also it is a 94 if that helps any. Thanks
Looks like the heat shield on/near the O2 sensors on the catalytic converter. Then again, the marking on it suggests it's too small for the exhaust pipe and unless you have little kid hands the bolt pattern it too wide for the O2 sensor shield. Do you have e-lockers? Maybe the shield for the actuator.
definately the O2 shields...
look at the header, just under the floorwell of the passenger side, up near the body.
On top of the pipes.
o2 sensor shield +1
But if it came off like that.... what happened to your O2 sensor?
The bolts that hold your O2 sensor on also hold that shield in place.
no I removed mine with tin snips and an angle grinder out of frustration, not having them makes changing the sensor a PITA.
Mine is also not a DD.
