- Joined
- Mar 13, 2014
- Threads
- 18
- Messages
- 50
I have a 93 land cruiser that I swear I done everything to make it run perfect but I keep getting a random loss of power while accelerating that goes away after a few seconds then might not come back for 20 mins or the next time I drive. Other than that it runs perfect with lots of power.
I done the following:
Plugs & wires
cap & rotor
all vac lines
IAC Valve Toyota
TPS Toyota
Bypass EGR
Bypass Pair
Cleaned Injectors & connectors
New NTK O2 Sensors
Put dielectric grease on all connections
Clean Throttle Body
PCV Valve
Denso fuel pump
Fuel Pressure regulator Toyota
Valve Cover Gasket & Spark Plug Tube Seals
NO CEL
Timing at a Perfect 3 BTDC with e1 & te1
Very Smooth Idle
I am thinking maybe the VAF Meter is just worn out? I took the cover off and cleaned it with electronics cleaner and resealed? Maybe computer or wiring? Ideas?
Plugs & wires
cap & rotor
all vac lines
IAC Valve Toyota
TPS Toyota
Bypass EGR
Bypass Pair
New NTK O2 Sensors
Clean Throttle Body
PCV Valve
Denso fuel pump
NO CEL
Very Smooth Idle
