Radio install kit questions
North carolina
Website
minutemansignsinc.com
I have a 97 fzj80, and am very confused on which kit to buy (My cd drive is shot). One on walmart.com lists years 91-96
https://www.walmart.com/ip/TOYOTA-1...-RADIO-CD-PLAYER-RECEIVER-INSTALL-M/716719030
Then ive got amazon with 97-00
Amazon.com: Stereo Install Dash Kit Toyota Landcruiser 97 98 99 00 (car radio wiring installation parts): Car Electronics
Is this a typo since these are 2 different series trucks?
I want to go single din kit and mount a full size ham(vhf/uhf) radio underneith. noticed 3 connectors i believe going to the back of my radio when i inspected it last week. Also, any recomendations on stereos that have the amazing sound quality as the stock unit?(my wife was super impressed over our rav4 stock unit).
Also, i found the "official dash light thread" on here last week, then spent 2 hours last night trying relocate it if any of you gentleman would be so kind to drop me that link, it would be greatly appreciated. Cheers!
noticed 3 connectors i believe going to the back of my radio when i inspected it last week. Also, any recommendations on stereos that have the amazing sound quality as the stock unit?(my wife was super impressed over our rav4 stock unit).
I think 2 of the 3 connectors are for for a "normal" radio, and the third is if you want to bypass (and add an aftermarket amp). I used this harness when I mounted my (somewhat disappointing) double DIN unit.
so indeed the 2-plug metra 70-1761 is the "Standard" - provided you fully disconnect the OEM amp.
nearly all h/u install the same - ISO din which screws into the factory mounts -
you likley wont even need a cover bezel - as the h/u tend to five very flush and as the HVAC control bezel is on large unit -
you simply cannot put it on - so it looks very clean...
so there really is no "kit" - just the hardness and a new h/u
models - really depend on look and feel and $$$ - check on cruthcfield -
ive always like JVC and Alpine - but i doubt any sound better than the next - sony, kenwood, pioneer, hell even jensen....
i personally went with a digital media player - ditching all my CDs and plugging in my iphone.
somehitng like this...
JVC KD-X33MBS
kits are more these -
Amazon.com: DKMUS Universal Radio Pocket for Toyota Honda Mitsubishi Lexus Cd Storage Single Din Install Mounting Dash Trim Kit: GPS & Navigation
converting a single din H/u to a pocket covering -
now not knowing much about ham radios - sadly am not aware of any mounting kits to place a ham radio in a ISO / dash din.
am sure it can be done - with first custom brakcets - but again i dont believe ham radios are standard din sized...
Bf
For the single DIN I'd go with the Amazon kit or no kit at all. The Walmart one has the tray underneath but that will be in the way of your HAM radio. If you are going away from stock head unit you'll also need the wire harness to connect back to the factory amp (assuming you keep it):
Amazon.com: Metra 70-8112 Radio Wiring Harness for Toyota Amp Integration 15 Pin: Car Electronics
As for brand I personally always go with Alpine. Quality build, sound great and prices aren't bad. Plus most of them have color adjustable backlighting so can make it match your factory interior lights.
For what its worth if you want better sound quality ditch the factory amp when you replace the head unit. The factory system sounded good for 1997 but todays systems blow it out of the water. Its more work but the end result is well worth it if you care about sound quality. I was able to squeeze a small Rockford Fosgate Amp made for UTV's in the same location as the factory amp. The difference is night and day (I had already replaced my factory speaker though).
Yes! That is the led thread I was looking for thank you..
I meant single din. that was the missing harness I couldn't figure out. I am sure mine is the "premium sound" with amp- I think I will work it since it's still functioning. Thanks for the feedback!
The stock amp has only a couple of watts output, if I remember correctly. Anything new will beat that. If the replacement unit has a preamp, it will probably match the OEM unit. If not, you'll need an amp anyway.
Your limiting factor is the speakers. Assume that the factory speakers are all 4-Ohm and add them up, that way you won't overdrive them. You need to determine whether you have a four speaker or nine speaker system.
By the way, Crutchfield.com is a great resource, even if you don't buy anything from them. They do have aftermarket harnesses which perfectly fit the landcruiser.
Replacing the speakers and keeping the factory amp gets a marginal improvement. What you will find is the factory amp is too small to drive even low grade speakers these days. It's also set up to run "surround sound" so it sends less power to run the rear door speakers and the 4 small tweeters (assuming 9 speaker system and assuming the small tweeters still work at all).
You should get an amp that has the same or higher RMS rating as your speakers. Then adjust the gain down on the amp to avoid speaker damage. This is better than buying an under powered amp. Under powering speakers can cause damage too, especially if you are maxing out your volume control and gains to get the sound levels you want.
I replaced my front and rear door speakers with 6.5"s, new amp, and disconnected the rest. Sound volume and quality is so much better. May add a small sub at some point but pretty happy with what I have. Alpine head unit, Rockford Fosgate amp and Hertz speakers.
