Radio and clock not working.
IL
I installed a double din head unit and it worked for a couple of seconds and then turned off. I pulled it out and some how the power wore broke. I soldered and heat shrunk each wire and reinstalled the head unit. It will not turn on either will the clock. My first thought was I blew the fuse but the fuse is fine and the antenna still works. I was thinking maybe it was the head unit but why wouldn't the clock work.
Should be two fuses. Also check dome fuse.
Yes, if I remember correctly.
Yes, the dome fuse is under the hood. It will kill your clock and the dome light, and will also kill your radio battery backup for radio stations. Some radios may not work if that battery backup is not connected.
Thanks. Sounds like that's the issue. I haven't had a chance to look. The 80s at the Mechanic having a code troubleshooted.
I talked to a buddy of mine who runs the install bay at a best buy near by. He said he'd run the power wire from the radio straight to the ignition. Any thoughts?
Yes, Best Buy is where I get all my electronics information from.
