Radiator Questions
Washington
I guess this is more of an accessories question then a radiator question, but here it goes. I have an aluminum radiator with a puller fan. In front of the radiator I have mounted a large A/C condensor. Would it be smart/better to put a tranny cooler with a pusher fan in front of that or put the tranny cooler and fan somewhere under the truck.
Either
Fan pusher --> Tranny cooler --> A/C Condensor --> Radiator --> Fan Puller
or
A/C Condensor --> Radiator --> Fan puller | remote mounted tranny cooler with fan
I hope that makes some sense.
Thanks,
Ryan.
Tell you the truth I haven't even got it started yet. I have just been told several times that I am going to have cooling problems. I know that I will need a transmission cooler, but I want to make sure that putting a transmission cooler in front of the A/C condensor and radiator won't make it too hot.
I guess maybe a little more background would help. I am transplanting a 4.7L supercharged Tundra motor into my FJ55. The 55 never had A/C or an automatic transmission. I bought a Ron Davis 19X22 aluminum radiator with a built in fan. In front of that I am using a 12x18 A/C condensor. The condensor blocks a lot of the radiator, and I was trying to think of ways to mount the tranny cooler that would keep the tranny cool, and not add significantly overheating the motor.
I will try and get some photos tomorrow of the radiator and A/C condensor.
Thanks,
Ryan.
Thanks,
Ryan.
GM does it all the time;)
I really do not think that you are going to have cooling issues with this...if the radiator has a fan and shroud assembly built into it, you should be fine bud.
Perhaps if you were looking at trying to cool a 500+ HP big block, you *might* have issues....
:beer:
