radiator help
Woodstock, GA
I'm trying to make up my mind whether to get my radiator cleaned out or re-built, or whether to replace it.
I don't think it's leaking, but whenI put a pressure tester on it I did see a few drops at the corner of the mounting bracket. It may have just been running down a hose. I didn't see it later. But the fins are fairly well smashed in the front and the back and I'm sure it would cool more efficiently if that was fixed.
I looked at the CCOT aftermarket 4-row replacement, but it says it won't work with factory power steering (which mine has) and factory A/C, (which mine had) and I figure it has to do with the 3 slot pulley on the front of the engine. I don't want to take that off because I plan to put the factory A/C back on at some point.
I want one made of brass like the OEM, but I don't want to pay $500 for the OEM model.
Does anyone have any info/sources for something that will work?
Thanks for any help you can give me!
I would say replace the radiator. I had cooling issues on my 1980 fj40 and had mine cored a few times, but I had to replace it to keep it running cool on the highway in the summer. I got a 4-row through a mechanic (I think it was downey, but not sure.), and it installed fine with power steering has cooled flawlessly. I'm not sure with a/c though.
I decided to just replace it. for a much cheaper price, you can find a new radiator that has a great warranty versus paying to have an old radiator cleaned out and hope it works. with my Chevy 350, keeping cool in the summer is key. Just seems these days, when I looked last summer, buying was cheaper and more reasonsable than salavage with most radiators.
Factory A/C trucks have a different radiator frame, shroud and radiator... among other components, like the right front engine mount, battery frame mount, etc...compared to non-A/C trucks...
If you are not using the A/C, find a radiator frame and shroud, and then get a 4core from CCOT or any of the other vendors on line that sell 4 core radiators and run it.
Good luck!
-Steve
I knew about the engine mount and the battery, but didn't know about the rad mount. Is it just for the screw holes for the condenser, or is it a differnnt size altogether?
And why do they mention the power steering as being a problem? I figured it was just because of the longer 3 slot pulley...
I thought about changing things so I could use the standard radiator, but I am really planning on putting the A/C back on at some point. I have a farm in S. GA and it's HOT down there in the summer!
Thanks!
