Radiator drain plug stuck... help?
tstockto
Somewhere between Bee Cave & Dripping Springs, TX
PO had a new radiator core installed just prior to me purchasing a couple months ago. I was told it was full of 100% distilled water and to run it like that for 500 or so miles, then drain and fill with real coolant (got the toyota red, going to go 50/50). Sounds easy enough... but I cannot for the life of me get the drain cock to move. I've searched the forums to see if it is reverse threaded or something but I can't seem to find an answer. I'm really hesitant to break out the impact wrench on this, since it seems very soft where it meets the radiator itself. Even with my puny ratchet I'm afraid I'm going to break it off. I can get a hex wrench on the top part to help with that, but good gravy... that thing won't budge. I'm curious how this drain cock works - it looks like it screws into the radiator and then this bolt opens/closes the drain. but one of them would have to be reverse threaded, yes? what am I missing here? (let it be known the bulk of my mechanical knowledge comes from mud and youtube....with a healthy dose of trial and error)
Wrench on top portion, wrench on bottom portion, lefty-loosey.
Nothing reversed here.
If your new A/F requires to be mixed 50/50, use distilled water. Tap water has too many impurities in it, and can create corrosion problem in the future.
If you damage it, the radiator’s coming out anyway. So maybe after exhausting all non-damaging tries, it may be worth your while to remove radiator, so you can get to it better. Also, I have run across several radiator drain valves that indeed worked backwards. Drove me nuts and they got replaced straight away.
And your mechanical knowledge is coming from excellent resources. Good luck!
Thanks for the words of wisdom! I exhausted my efforts on the radiator drain... block drain opened right up and is raining now. Glad it wasn’t plugged up like I’ve read about. Will remove lower hose and go from there. Thanks @Dizzy for the winning solution for me.
And yes, using distilled to get to 50/50.
