Radiator Drain Plug Frozen
New Mexico
Like the title says it won't budge. Has anyone had any luck freeing one of these up? The tube and petcock are quite fragile, if I can gently work it loose by penetrant and a little bit of heat I would give that a try. The rest of the radiator is in good shape and I don't want to risk breaking it, I can always drain it pulling the lower hose as a last resort, messy but doable. Suggestions?
Pull the hose for now, and when you later pull the radiator, then remove it carefully, apply anti-seize and reinstall. You will likely damage the tube if you try to loosen it in-situ.
