Radiator cooling problem
I have recently installed a 350 chevy motor into a 1973 fj-40 i have placed the engine to the rear close to the firewall going with the stock trans placement. I used advance adaptors motor mounts and went off their specs. Retaining heater controls. My stock radiator is not cooling / with electric fan. I want to buy a new radiator and fan what would you recommend? My stock placement I feel is too far forward to use a fixed fan?
i have a 350 in my 76 FJ40 and it cools fine, i went with a new 4 core radiator from www.coolcruisers.com but i think www.radiatorbarn.com has a better price. my engine placement sounds simular to yours but i had room for a flex fan and 2in. spacer on the fan. i used the factory fan shroud and turned it upside down and cut a notch so it would fit without hitting the lower radiator hose, works great never gets past the first line on the gauge even on hot days sitting in heavy trafic. hope this helps a little!
OH and welcom newbie :flipoff2: (thats hello)
Have you had your stock radiator recored? If you are using it as a straight swap there may be major buildup in the radiator and thus it won't do it's job to cool correctly. I took my stock radiator to a rad shop and had them recore it to a 4 core radiator. This along with a ford taurus electric fan helped greatly. Search for taurus fan on this and pirate4x4 and you will get lots of info. This was one of the best conversions I have ever done. Super easy, cheap and made a big difference.
Noah
You can recore your stock radiator will do a little better, but I can bet if you drive on the highway it will get hotter the faster you go. Ask me how I know. If you live in a cold climate you won't have an issue with a stock radiator with a 350, but not so in a hot climate such as Arizona or California...
Only cure is a larger surface area radiator. Save youself the time,$$$$, and frustration, do it right the first time and enjoy the ride!
I am in So Cal, and went throught this as well. New "Stock" type Rad with pusher and puller fan, New Alum "Stock" type Rad with pusher and puller fan, and now I am on a larger Alum Rad with only a puller fan, and it is working well so far.
Go aluminum, baby!!
I am running the coolcruiser radiator with a taurus 2 speed electric fan. Cools pretty good for the Texas heat. The fan helped over the other electric fan I had. So far the highest has been 210 on the highway on a hot day.
If you are going to go with a new radiator, go with the biggest aluminum one you can fit. I wish I would have done that now.
