Radiator cap pressurized when cold
Atlanta, GA
Thank you all for the help over the last few months. Just realized this problem and am reading as much as I can on it.
97 LX, 213k miles. I have owned since February and put about 4 k miles on it. When I bought, I baselined as much as I could. This included all fluid - just a drain and fill in coolant as I did not have the space to do full flush.
After drain and filling coolant (always Toyota red) I saw that when cold, the overflow level was at the low mark and when hot, the fluid got about half way up overflow. I topped off so that when hot, overflow is at full and when cold, it is about half way full.
In these 4k miles, coolant level has stayed steady. No changes to lines, no additions. Temps have always read a little higher than I would like (190-205 when hot outside, higher sometimes on hills) but never over heating.
Flash forward to today. I have ordered a belt kit and new fan clutch to address temps. Open over f low bottle to look for any sludge, coolant drips out of hose and all looks good. Take another look at radiator and decide to take cap off. Cap popped slightly, not up in air but enough to spill about 2-3 tablespoon of coolant.
Truck had not been driven in 4 days and temp was about 90 outside. Radiator cap is not original, it is a prestone 13 psi.
Radiator is full. Coolant all the way up to cap. No air. Overflow tank has been working as I thought it should. no sludge in oil or on oil cap. Hoping I just need new radiator cap?
Any help appreciated. Thank you!
If it gets cold at night, the thermal contraction can pull coolant in. Then if it's 90 degrees out, the pressure won't be high enough to let any coolant back into the tank and it will be slightly pressurized.
I would think this is normal
I agree with normal.
Well damn, that sounds easy. Thanks for the replys.
I am in GA, at night it is getting down to 74-75. Not very cold. Still seem like normal operation at 90? Truck was sitting in the sun too...90 might be conservative. It's jungle hot in GA right now!
Thanks
Rob
My new OEM cap goes "sssshhhhh" when I open it after sitting for a few days. If it holds pressure for that long, I think that's a good sign. So, I'd say normal operation.
Sounds good, thanks for the replys. I was expecting doom and gloom - too much of my left over Jeep days making me think the glass is half empty!
