radiatior mount and shroud
looks pimp.
Holy heavy duty Batman! The only thing that may be worth adding before paint would be tabs for tranny/power steering/oil cooler. Are you stabilizing it from the rear as well?
Bret,
I actually liked your idea that you did with the trans cooler, so yes...ill be using that same method for the trans cooler.
Off the vertical braces, I plan to wrap a piece around the tanks on both sides of the rad and make another x brace, horizontally at the top on the fan side to better secure the rad. in place by the cap. So the cap will have 4 bolts, 2 on front, 2 on back at the cap, so the clamping is evenly distributed.
As far as running braces like you did down to the frame on the fan side....I havent decided to do that. Im gonna see how it is.
Im kinda thinking it wont need it as the base will be secured by 6 bolts into the frame already. Best I can tell with the way its set up NOW is lateral movement will be the issue...hence the wrap around pieces.
