Rack preferences for RTT
Fort Collins, colorado
We are looking at getting a rooftop tent for the summer, wondering peoples personal experiences on whether doing the entire thing flat or having a raised expo part in the front, does it really matter as far as The tent goes and where you can position it?
The one thing to keep in mind is the spring rods that hold up the window shade's/fly. They slide in the base part of the tent and then curve up to the fabric. They need to have room......1 to be installed each time and then to allow for the curve to happen.
This is assuming you are getting a fabric fold out rtt not a hard shell. If its a hard shell then these are not concerns.
Are you talking the distance of the rack to the roof of the vehicle?
Yes, we are looking at a Tepui.
The bottom of the fabric tents like Tepui's and others is an aluminum sandwich. It has holes drilled diagonally on all 4 sides to allow the spring rods with hooked ends to be inserted then curved up to hook through the window covers and the rain fly depending on which side. You need a clear space to feed the rods into the holes and if you have a rack that blocks that then you will not be able to use them. I know this because I mounted my side awning at the same level as my base on an offroad trailer I built and was unable to use the rods properly on the end of the tent nearest to it. The rods are not really bendable around corners. They are made to slide straight in with very close tolerance then curve up. Google pictures of RTT's and you will see what I am referring to. Hope this helps.
If need be, you could drill out holes in the rack where the spring rods go. I had to drill new ones in the base due to quality control issues with CVT.
Sent from my iPhone
I used 4 yakima crossbars for years and finally got around to building a full length flat rack. I was tempted to have a basket up front but thought it would affect the versatility. I was right, the flat rack has been the best. I can load the largest rtt up there and have room for two action packers in front over the sunroof area. I can easily haul the canoe around. Full sheets of ply and 12 ft 2x4s are no problem either.
Forgot the pic.
I have the PrinSu Designs rack (flat) with a Tepui tent and two ARB awnings that live on my roof all the time. I love this rack! I recently took a trip with two other folks and had well over 600lbs of humanity in the tent. No deflection whatsoever. It's also cheaper and lighter than most other racks. Pics and install notes in my thread in my signature line.
The advantage of an expo rack is that it is a little more secure holding stuff in the basket vs being flat. It may get in your way though when opening and closing the tent and certain racks may get in the way of the shade rods extending. I spaced my tent away from the basket about 4" to make it easier to open and close. I've grown to like the setup. You also can leave stuff up top unsecured when you're camping and don't have to worry about them falling off.
But if I could do it again, I'd probably go flat for the flexibility
I've got the flip style rtt now but was strongly thinking about selling it and getting a hard top. Lots of trees on the east coast. How's your cover held up?
Sent from my iPhone
^^^ that's my favorite and what I'd order if I fidnt already have a front runner slimline. Well a wind cheetah actually.
My vote was at the time a flat rack but if you don't need extra storage or plan on a hard clamshell rtt then I would consider load bars instead. Rhino rack or others are available
