I'm finally getting my wiring squared away for the rear locker (arb) and have a question:
from the FSM wiring diagram, it appears that the locker lights take + from the dome fuse, then run it through the light bulb, then go from there out the wiring harness (presumably to be grounded by the elec locker ECU).
So I plan to run wire from +, to the ARB solenoid, then to a switch on the dash, then to ground (to activate the solenoid) but also to run a wire from the Locker light to the same pole on the same switch, and thus to ground.
Should work, right?
Also: I'd like an indicator for the air compressor... any suggestions for unused spots?
Just for the sake of typing it out: here is how I'm wiring the whole kit n kaboodle:
+ from battery (through 60A fuse) to the rear of the truck via 6ga cable. For now- to a bolt. Eventually to a fuse box.
relay terminals connected as follows:
87: to 25A fuse -> + power.
85: jumped to 87
86: to dash switch -> ground (maybe an indicator light also wired to switch)
30: to Compressor . Also to ARB solenoid.
The other pole of the ARB solenoid will go to its own dash switch, which will also be connected to the RR locker light, and to ground.
Thus it should work that when I switch the compressor switch, it energizes the compressor, and also puts power to the solenoid, so that it can only turn on when the compressor is "live"
Thoughts are welcome.
Should work, right?
85: jumped to 87
