I apologize if this has been posted before. Is there any way ARB lockers can be integrated with the stock diff lock lights inside the gauge instrumental panel? My 97 LC doesn't have a diff lock but it seems to have those lights. I guess it came standard regardless of equipped with lockers or not.
I need to do the same thing eventually. I believe, you need to switch ground in order to get these lights to come on in the dash. You'll need to tap into the Diff Lock ECU harness that I think (if memory serves) somewhere near the pass foot well? Let me know if you're succesful so that I can simply copy you!!!
Yes, it can be done. I have ARBs in my beater which did not come with the elocker. I also use the OEM rotary dial switch. You’ll have to put the lights in the combination meter and will have to wire in the ARBs but it can be done.
Guys can you please put this installation into a well detailed steps, so newbies may follow your footsteps. I would like to go ARB, install the rotary switch, put the light bulbs in the socket on the dash panel. I would like to make it OEM look and stealthy.
OK, newbies should not mess with power If you use the factory switch ( the harness is there), you can tap out of the wires (output side of the switch) and run the two solenoids from this.
If you do this then there will be two pins on the locker ECU plug (right front kick panel) that will also get 12v when the switch is turned. On the same plug are the ground side of the two lights (that Junk mentioned to be installed on combination meter (dash for newbies)) Use the +12 signals to trigger small relays that take the ground side of the ligth to actual ground. This will turn the light on.
Thank you for the great info. Yes it will be really helpful if anyone can point me to the link where there's a detail instruction. sleeoffroad, I see what are you talking about. I would love to use the factory switch. I guess only other switch I would have to install is the air compressor. So the harness comes with the switch or it's already in the truck (if I read you right)?
So has any one been able to come up with a detailed instruction on this, is it already out there some where? Any link? I've got my OEM switch and the ARB compressor. I would like to at least get this things installed before my 3rd member shows up.
Riad, not to offend, but doing electronics on your car from step by step instructions are a recipy for disaster. Either find out how this works and understand it, or have someone that knows do it. Doing this incorrectly you stand a good chance of toasting your whole instrument cluster and more.
Riad, not to offend, but doing electronics on your car from step by step instructions are a recipe for disaster. Either find out how this works and understand it, or have someone that knows do it. Doing this incorrectly you stand a good chance of toasting your whole instrument cluster and more.
Thank you sleeoffroad. I know that. Maybe that's why there's no step by step instruction . I will call nearby LC specialist, which is about 60 miles away, see if they can install this. There's no way I can do this myself. I have the EWD, looking at it makes a lot of sense, I read (Hard/Soft ware) schematic, that's part of what I do for living but there's no way I will/can do this myself without some serious help. That's why I was asking around . I appreciate your advice?
I use a different air compressor (York) so I didn't have to deal with ARB's "harness". Not having the harness makes it easier, in some sense, to come up with the wiring for lockers and the air compressor. I believe that ARB wants you to lock the front first then the rear locker - in that order. This adds a bit more complications to the wiring harness.
Here's what I needed:
A heavy duty relay (SPST)
OEM locker selector switch
Aftermarket switch for air compressor
A pressure switch
bunch of wires (multiple colors)
A circuit breaker
For a simple wiring diagram, I copied this PDF from Sunperformance.com's site. If the picture is too small, go to the site, click on Install Diagrams, then choose any of the schematics you want.
For right now, I'd recommend that you simply install the air compressor, locker solenoids and the OEM switch. After you get everything operational, then worry about the DIFF LOCK icons in the dashboard sometime in the future.
Thank you very much Ali. This is much better and helpful. I actually finally found a vendor who can do this and has done the same to his own truck. He hacked into the ECU and set up the relays to do this. He installed new lights in the dash as well. He also used the ARB harness and wires. What is very interesting to me is that he is now working on to get rid of the air compressor and use some sort of supercharger pulley to produce air for the lockers. That's exciting!! Anyway, yours look a bit different. Yes ARB compressor locks the rear first, as far as I remember, it will not let you lock the front without locking the rear. And our stock OEM switch is technically like that as well. It locks the rear first and then the front. Also looks like the FJ80 has another interesting feature. And that is you cannot lock the front or rear diffs without locking the center diff. Not sure if this applies for all FJ80s w or w/o lockers. I guess this can be changed but I am happy with locking the center first. I know there's an after market switch for that too for high range, anyway that's a different topic.
Thanks a lot every one. This entire installation will take many hours. I will see if I can manage to be around when the electrical part is performed so that I can document it with pictures if possible. This would help newb like me and every one else who wants to do the same
Arright. I hate to bring this up again. Pulled out the dash and cluster and installed the DIFF lock lights and the rotory DIFF lock switch. Man that was some experience, and it looks real!! Toyota put a white tape over the two holes for these lights in the instrumental panel. I had to call around all the dealers within 70 miles to find the sockets for the lights. Not very many of them carry these stuff. Anyway I have got 2 relays. I know I have to power these relays from the ECU using +12 V, pin 12 and 6. And switch pins 2 and 9 to ground to turn on the lights. Can some one PLEASE provide me a drawing for this? I have EWD but I need the drawing for the relays. I simply connected pin 9 to ground to see how it looks. The front DIFF LOCK light came on (red) when I turned the ignition key on. Now I at least know how it looks.
OK, so you have to do the same thing with the relay. Do you know how a relay works? If not do a search on Google and locate a site. Again, be carefull if you do this wrong, you are going to send 12v up to your instrument cluster and then you are in a whole lot of hurt.
Riad, I really do not want to sound like I am beating on you, but I PM'ed you the instructions on how to do it. Provided you understand the instructions. It should have been pretty easy. I am all for people doing their own mods, but provided they learn in the process. Not everything can be done from a recipe.
Christo, Yes you did and it was clear to an extent. I played with relays many years ago, I understand the basics of elctromagnet and how an armature can switch a component to on/off. I am all for learning and that's exactly what I am trying to do. I can build up a simple light circuit using relays but since I am in the process of learning the wiring for my truck, connecting relays to it is a new thing to me. Again, I am learning and trying to make it to work, . And I appreciate your help, 1000 times. You can beat on me but I really need/want to (Re)learn this.
So, pin 12 is going to power up the relay, my assumption/understanding is I connect pin 12 (+12V) on one side of NC (Normally Closed) leg of the relay. This will attract the armature (coil of the relay) where on one side pin 9 (rear DIFF light) can be connected and the other side can go to ground. I do the same thing with pin 6 (+12V), pin 2 (front DIFF light) and 2nd relay. Therefore, when I turn the rotory DIFF lock switch to RR, the rear light should come on and respectively to RR/FR, the front DIFF light should be on. Here is the drawing for the relay:
Am I right? or wrong?
No, you connect 12v to the coil, other side to ground. You connect the pins for the lights to the NO side of the switch and then the COM side of the switc side goes to ground.
