Quick question on Warn M8000
Orlando, FL & Southampton, NY
I'm still debating on which winch to mount behind the bumper on my 80 and it looks like it might be a Warn M8K :cool:
Just curious, but would it be possible to rotate the housing for the clutch end so that the level faces downward :confused:
Since it's going behind the front bumper, I'll need a way to access it easier....
you need to rotate all of it together because of the mounting bolt locations
Here's the answer I just got back from Warn:
Rick,
The clutch lever can be rotated as long as it’s rotated in increments of two bolts.
For example you could not move the clutch housing 3 bolt holes, it would need
to be moved 4. This is due to the clocking inside the gear end.
Thanks,
Rich Kadwell
Technical Customer Service Rep.
Ph# 800-543-9276
Fax# 503-722-3000
