Quick oil change question
Utah
The FSM states that the 3FE takes 8.2 qts of oil with a filter change.
The last few times I've changed my oil, I noticed that when I put in 8 qts, it would read high on the dipstick, like 1/2 qt over.
It runs like a champ, just a little ticking from the valves and nothing more.
Why does my 3FE only take 7.5 instead of the specified 8.2?
EDIT: To clarify, this is after I let it run for a few minutes.
When are you checking the level? If you are dumping all 8 quarts in after you put drain plug in and filter on, and then checking level before cranking the engine, the oil hasn't circulated through the filter yet and is giving you the false high oil level. Put 7 1/2 in, crank engine and idle for a couple of minutes. Shut off and let it set while you clean up (15-30 min). Then check oil level and add to full mark. Also always check your oil level while parked on level surface and before you run vehicle for the day (after oil has settled over night) for the most accurate reading. HTH
This is after I've started it. The problem is that even after I let it sit for a while, it STILL reads high. I check it multiple times over the first 1,000 miles. Same reading. After that, it starts to leak/burn/whatever.
Is it possible that the container(s) that you're using to fill your oil with are not accurate? Some times a "quart" bottle of oil contains more than a quart and after adding 8 quart bottles of 1.1 (for example) quarts would add up to about 9 quarts. FWIW
I previously used two 1 gallon jugs (8 qts) of Rotella-T 5W-40. 1/2 qt over.
Before that, I used the 15W-40 oil gun at work (very accurate). 1/2 qt over.
Now I use 1 five-quart jug and three 1-qt bottles of Valvoline 20W-50. Still 1/2 qt over.
Food for thought, though... :hhmm:
I just dump in 2 gallons and don't check. Then it gets checked once a month for that run of oil. It never really seems to matter and they always read at the full line. I would not sweat the 1/2 quart.
See, I try to be lenient like that, but I'm OCD and can't help it. :bang:
:meh:
Mine ('91) takes exactly seven quarts, including replacing the "big" filter. They're all a little different. Use however much it takes to get it to read in range on the dipstick when engine is warm and has been sitting for 5 minutes or so (as per the owner's manual).
Curtis
Yeah, I've been getting really suspicious of the "markings" on the oil containers and their true content now a days. I use 1 gallon containers of Amsoil and measure out the oil that I put in with an Amsoil quart bottle with Fluid ounce marking on it. I've also used the 5 quart containers that you're talking about on my kid's vehicles. I've seen some real inconsistencies. It's almost to the point of using the:princess: Pyrex glass measuring cup - that'll make her scream:hillbilly:
:lol:
I'm worried though because I don't have any dents in the oil pan (yet), and I've worked on a few other 3FE's that take 8-8.5 qts...
:meh:
Curtis
7?
Mine is the same. I had been using a Mobil 1 filter with 2 gallon jugs of either 15W-40, or SAE 30 Rotella T. I always read a tiny bit above the full mark with the Mobil 1. This time I switched to a Bosch filter which is slightly smaller, so now I read about a 1/2 quart high. I don't think it matters too much though. These things have such a large capacity that that much doesn't seem to affect them. My dads Bonanza always blows out till its settles in at half a quart low. Won't keep it totally full, but won't burn anymore after it blows out that 1/2 quart so I think the engine will get rid of it if its not too happy with the amount. My 3FE never loses any oil till its time for the change, then drops about a 1/2 quart so I think it all evens out. : ).
Here's a little something to think about. About 8-9 months ago I flushed my engine with Amsoil engine flush. I was having some trouble with the drain plug not sealing so I just stuck the old one in all night after all oil had drained out. The next day I got the new drain plug and gasket from dealer. When I went to take the old drain plug out my truck drained another 1/2 quart or so. Maybe the 8.2 is a completely dry fill
I'd agree with the "dry fill" thought process. So...when the motor does blow up....and you've rebuilt it then you'll for sure know what the real world capacity of it is.
Also, have you lost any watches or pocket change when doing engine work? Maybe they are down there in the oil pan taking up space???
