quick and dirty platform in bed
Santa Rosa, CA
I'm running Rubicon in a couple of weeks and I wanted to both increase my storage and see if I could make a platform that would alllow me to sleep in the back of the 40 if I wanted to. I didn't want to spend a lot of money and I didn't want it to take a lot of time.
Seat bracket was already there, I just added the upright.
Couldn't the full platform in the back, had to cut it in half, so this is both support and it splices it together.
If I had an RTT on, i’d Rip it off before Buck Island Lake
Yes, it's long enough, but it gets narrow between the center console and the B pillar bar of the roll cage. I'm very tempted to raise it up about 6" that would put it on top of the bottom roll case cross bar and over the center console. It would create a lot more room, but the section over the console and shifter would have to be removed to drive.
Awesome... thanks for the reply! I would also have concerns about the narrow space up front... I’m about 6’1”. I also have a Tuffy center console and mine sits up even higher.
I’ve also thought about going over the center console, but the solution would have to be modular when driving and I’m just not smart enough (with wood or metal fab) to figure it out! You would also then have to brace the sides over the wheel wells, etc. Your current solution is very simple and clean! Keep us updated on your progress and I’d love to see as many pics as you have...
Yes, that's where I put my feet, it's fine. If your taller, you could always devise a short extension out the bed to accommodate your head.
In my case, I'd just use the roll cage cross bars to support the platform over the wheel wells, that would set my height.
And yes, the part that would have to modular would be tricky - but, it wouldn't have to hold much weight.
Cool!
Did you ever consider something like a sheet of plywood that sits directly on the bottom of the tub floor. With a second sheet of same size hinged to the first piece. The hinge end would sit over the sill and the top half would unfold behind the truck. two adjustable height legs (to account for uneven ground) would support the unfolded piece. The legs could be hinged perpendicular to the other hinges so the legs would lie flat right behind the seats and simply unfold under the platform.
I was thinking of doing something like this for a Tailgate table, but seems like it might work for this purpose also plus give you the option for keeping the passenger seat as well as more storage room in the back since everything would lie flat on the floor. Might need a little addition support to hold the weight of your body but that would be pretty easy to add. Obviously if you were looking to have something over your head during the night you would need to rig a canvas roof or something.
Now I'm motivated to get going on my tailgate table!
Yes, that was my first idea. But, I'd need a pretty sophisticated set of telescoping legs for it to work. And, I wanted the extra storage under the platform. The back become such a mess of different bags for different purposes. I'm hoping I can keep the recovery stuff and the kitchen stuff in storage bins underneath (heavy stuff down low) and the food and personal stuff on top.
But, if I were to do that. and I might eventually so I can have somebody in the passenger seat, I'd support it off the hitch instead of the ground, that way as long as the rig is level the bed is level.
However, one of my issues is there's just not enough room in the back for the ARB fridge and all my gear, so this gives me a place to put the ARB next to me and the rest of the gear in the back.
You could probably also suspend it off of your beefy cage with some kind of cables or nylon strapping.
