Question on Temp Guage
Florida
Fellow LCer's,
Searched our site but still have a question on the Temperature Gauge / sending unit.
Had to replace my Head and broke the Temp sending unit when removing old head (just the tip of the sending unit). Ordered a Used replacement sending unit from SOR and installed. Gauge does not register. The question:
Put a light tester on the lead that attaches to the sending unit, it blinks. Is there something I am missing and is that normal? Will put a voltage tester on tonight but wondernig if blinking voltage is normal for that gauge.
Thanks.
Boaf
I did thread seal both the bottom and send unit, I removed the sending unit sealer, but not the bottom mount. Will do that tomorrow.
Thanks. Maybe the used one is no good.
Will let you know.
Boaf
Hello all,
Made sure there was no thread sealer on the sending unit and mounting unit. No luck, gauge still does not register.
I am getting fluctuating voltage on the electrical lead. I know the gauge works as it did prior to replacing the sending unit. Guess I can get another sending unit, but want to make sure that is the problem. Thoughts?
Boaf
If I remember right, there is a resistance change on the sender as it gets hotter and hotter. The gauge with voltage on it , just sense the resistance change and the needle moves accordingly. So, if you have a multimeter, as the vehicle warms up, you can check resistance from the temp sender post to ground. Then see the actual resistance and see it is steady. Also ensure with manual that the sender is correct for the gauge.
The FSM has the specs on what resistance is at what temperatures. I would bench test the used one from SOR before scrapping it.
A multimeter and a glass of hot water (known temp) are about all you need to test if it’s good or not.
Found it in my FSM.
Getting resistance, not per the spec but there. I will check continuity (and the Gauge). Gremlins!!! Thanks TLAPorte
Dont try this without checking it out .........sometimes you can ground the lead and the gauge will peg. Someone who knows fj40 wiring better than me should be able to confirm if this will test the gauge.
You are close. If you look at the manual, post #10, the hotter it gets the less resistance there is. So, if you short the top post the gauge will go to full hot. I would not hold it there long, just to check.
