Question after wheel bearing repack
Oviedo, FL
So I just replaced rotors, pads, front calipers, 1 wheel bearing, and then repacked it all.
When I'm going through curves/turns at speed, around 40+, I get a shake in the steering wheel (not violent shaking but easily noticeable). I've driven it 50 miles and it has stayed consistent. It feels fine driving straight and no wobble when braking.
I'm guessing I didn't tighten wheel bearings down enough?
I torqued the inner to 43 twice and then left it torqued at 30. Outer is torqued to 47.
You do new races as well on the new wheel bearing? You sure you got the race fully seated?
How about steering arm studs on the bottom of the knuckles? Check them!
Also, 43 lb-IN or lb-FT on the wheel bearings?
Jesus why did it post so many times.
I am also reading threads about how some left the inner torqued to 10 lb-FT? I'm only running 285's so maybe I don't need to be all the way at 30?
When you installed your rotors, did you torque them with a torque wrench in a "star" pattern?
Could be:
Warped or misaligned rotors
Loose steering arm
Loose wheel bearings
Did you get your star washers bent over on the tabs both inside and outside nuts?
Did you torque them while rotating?
Could be:
Loose steering arm
Main reason I replaced rotors because they were warped. There is no shaking when applying the brakes so I don't think it is that but yes they were torqued in a star pattern.
The tab was bent both ways and yes torqued the adjusting nuts and rotated at same time.
I'm still thinking something with the adjusting nuts need to be loosened or tightened. I wouldn't think steering arm as there was no shake at all before all of this (besides warped rotor shake).
I assume you didn't remove spindles/knuckles or other front end components?
I'd do the following:
  • Check lug nut torque, if all were tight proceed
  • Lift one of the front wheels off of the ground. Only lift one and use a big floor jack, jackstand or something secure to keep the front end stable. Don't remove wheel/tire
  • Grab the tire top and bottom and push/pull as hard as you can, feeling for any bearing play. Repeat this side to side, with two hands on top of tire, with a friend helping. etc. ;) until you feel like you've really given them a good test. You can even put a block on the ground and then use a long pry-bar to test but you may find trunion bearing slack, etc. not related to your bearing work. If you feel bearing slack, re-tighten the inner bearing...
  • While the wheels in the air spin the wheel so see if it spins well/quietly/etc. It wouldn't hurt to test for slack with the tire in different positions rotationally either.
  • Check the other front-wheel.
  • If no slack found then is it possible that the problem pre-existed your recent work? If so you can do a more thorough front-end inspection but if you are sure that this only started due to the bearing work and the above didn't solve the problem then you may need to dig into the bearings again?
Hope that helps.
Check the radius arm and the panhard bushes. I changed them on my 80 a while back because I was getting bad 'diff bounce' caused by the suspension setup I've got but made worse due to the bushes all being in bad shape.
I have fitted all new genuine bushes to the arms (superior eng superflex arms) and the front panhard rod. I haven't done the back panhard rod yet or bothered with sway bar bushes but that's on the to-do list.
285/75r16 tyres are what I run and they're difficult to balance.
So I neglected to mention at the start of this thread that I had rotated the tires at the same time I the bearings and brake work. Didn't really think it was some of the possibilities mentioned before as there was no sign of a problem before I started working on it. I decided to take a look at my wheel weights on the back of the wheels and for some reason they were gone off of all of them.
I had the tires balanced again hoping it would fix the problem and it did, no more shaking steering wheel! :cheers:
Glad it was just that and not the bearings/something loose.
