Purdy Truck Orion Thread
You are right Eric. We'll figure it out sooner or later.
Yeah Michael, The longer spacer is in the case right now. Ok, here is what we did: as we stabbed it together we addded the gear then the long spacer and fed that through the bearing. Then the shorter spacer, a thick washer and the stake nut. One thing I did notice is that the thick washer that came off the old case is dented a little from torqueing down on the old case. Could that be it? I guess I could flip it around and see if that helped. As we torqued the stace nut down it pushed the bearing into the cas a little (not much). We'll look at it tomorrow. Gotta get some gaskets if we have to break it apart again though.
here's a question:
when you guys took the t-case off the original 4spd, was the nut loose or was there play in the spacers/gear? i've seen the nuts come loose and then the spacers slowly wear on the ends. it's easy to tell with the spacers out of the case becuase the ends will look very shiny, not perfectly smooth from the machining process.
the gear mesh looks good so i think one of the spacers is shorter than it outta be.
i'd pull them back outta there or at least try to get a good measurement on the one in the case and i'll measure one i have here.
better safe than sorry.
and like michael pointed out, it'e important that the whole assembly is tight and nothing can "walk" back and forth.
hth
georg
ten phone calls later......i think we got it figured out. ;)
Tech calls were $5 when we started and $20 by time i left.. Cant imagine what they are priced at now :eek:
Gotta roll out the red carpet in moab for georg to drive on..
The thick washer was the problem. The one that was on the old case was dented in for some reason. I had 2 other washers off old cases that I had at the house. Problem solved. No play in the spacer and the gear meshes perfectly. Ready to stab in the truck tomorrow night. Jrob and I could use an extra hand if someone is available. Starting around 6 pm at JL Roberts.
You got it Georg! I'll hook you up.
You know i would if i could..
Little incapactiated to say the least.
Come on guys step up and give bodean & jrob a hand.
How else are we going to break a PBR Bottle over the grill ?
orangefj45 said:
i would'nt know what to do with it. so i'll take a cold :beer: instead.
What do you left coasters drink ? Colt 45, wild turkey or mad dog?
I know you can't "hold" your wine : p
ya had to go and bring that up again, didcha?! i thought your lovely wife had already forgotten about my mere existance.......
fosters. green or blue as long as it's cold. or spaten or pilsner. just no none of them domestic piss-beers. if i'm gonna drink a cold beer, then i want it to taste like sumtin! :cheers:
I hear ya! Not much on domestics.
I wonder if moab has yeungling?
not quite.....i spilled lenny's wife's wine all over her the first time we met. doubt she'll ever like me.:rolleyes:
She would have to remember you to like you ; )
Don't worry you guys will meet and you will be forgotten ...again.
Just don't do anything memorable like roll your truck on her or somethin'
Nobody will be forgotten on this trip!
