Well I just purchased this 99 Land Cruiser on Sunday and after driving it for a week I noticed it had a very noticeable pull to the right. I looked at the tires and they did not appear to be wearing uneven but did look like they needed a rotation, so I did that and still pulled to the right
So I decided to perform an alignment (Hunter Laser machine, it's an accurate machine)
All measurements showed within spec but a couple were close to being out so I adjusted the toe in the front and made sure my total toe was centered (previous to alignment total toe was off to the right, so i figured this was causing my pull)
I drove home and it is still pulling right not as bad but still will lane change in about 5 seconds or less..... I'm thinking of crossing the tires (left to right right to left) to see if the pull is a radial pull from a tire. But that is why I rotated from front to back the chances of having two tires that have radial pulls?? I purchased the truck with Pro Comp Mud Terrain tires (is this the nature of the beast), I usually do BFG's.... I'm still trying to decide what size tire and wheel I want to run so for the time being I'm going to drive on these tires, any ideas or help would be appreciated.......
