Update
Well got my winch spool back from my plating man. Took a bit to clean it as oil was soaked into the casting.(porous cast steel)
Spent a bit of time over one weekend looking at rope paths and winch positions.
Blew a hole in the front cross mount and decided where it would come out the bull bar.
Now thats been set the rest will follow.
I can get a straight run thru to the cross member behind the transfer case.
Next step is to locate the winch.
I have two options, slight direction change to the winch top of drum.
Or run it past and thru pulleys attached to the rear cross member and back to the bottom of the drum.
Doing this I can get the winch higher and align it more easily.
Will mock it up later.
Photo below is my mobile winch rack...Cause its really heavy to hold up......
Well I have been under the truck again this morning looking at winch v's rope position.
I can only see two ways to get maximum length so the cable will lay properly (according to the rope people I would need 4m) I can get 700mm give or take without major body mods... Trying to keep it factory as much as possible...
While keeping winch away from drive shaft and diffs and suspension and body work and also keeping rope away from the same...And still being able to drive the thing via the PTO. Have settled on solution one. (I think) Oh and allowing me to have a trap door in the floor pan so I can get to the shear pin.....
If I move winch back one bay it gets too close to the diff head for my liking.
(now if I cut its bum off...move fuel tank up hmmmm another day I think)
But solution two is possible but the rope gets rather close to left coil.
Both options rely on using two pulley's / sheaves.
Option one is also good as I only need to weld two tabs to the bottom of the cross member to mount the rear winch points.
Not sure why I took on this project .... Ahh thats right watching those winch trucks ...And I am a sucker for mechanical things / projects.
Oh and I am having the lads machine me up one of these for the front hawse / fairlead from stainless (cause its cheap)
