PTO broken
Belgium
Does anyone have an idea how to fix this PTO? The gearbox is broken when I was trying to remove the plug.
That's an odd way for that to break. Was the plug extremely tight, or the wrong plug that a previous owner forced in there?
A proper repair might include either a new case, or welding/drilling/retapping.
What Year is the cruiser? 81/82 is the hardest housing to locate. A 83+ you could switch the internal part from yours to a single direction. Those are easier to find. That is assuming yours is a two ditection which most all 4X series got.
The case is made of aluminum.
The cruiser is from 1980. It is indeed a cable switch two direction PTO.
I think I'd have that ground flush with the case, welded over entirely, and use a new bung nearby as a drain.
Unless those threads could be recreated perfectly a repaired drain would probably leak.
Needs a solid tig weldor either way.
