The easiest way I found:
Supplies:
3/8" barb
6' or longer of 3/8" tubing, clear vinyl makes it easier to see what is going on.
Small hose clamps
Cap for return port, I had a plastic shipping cap from a master cylinder that fit.
2-3 quarts of fluid
1. Set parking brake.
2. Lock cdl. (put in low or set cdl switch with key on)
3. Block rear tires.
4. Lift front axle so the tires clear the ground,
5. Set axle on jack stands being careful they will not interfere with the travel of the tires when turning, removing the front tires may be needed for clearance.
6. Enjoy the cold beverage of your choice.
7. Remove return line from the reservoir, it is the upper and smaller of the two hoses on the reservoir, it is a slip fit with a clamp. It comes in mid height on the side to a L shaped metal tube.
8. Catch the ~1/2 quart of fluid that drains from the return tube in the reservoir, then plug it so the reservoir can hold fluid.
9. Slide the barb into the return line you disconnected, slide the clear tubing on the barb, clamp both joints. Route the tube into a container or drain pan.
10. Fill reservoir with new fluid
11. Turn the key to acc to unlock the steering wheel but do not start engine, also do not leave in the "on" position for any length of time.
12. Slowly turn the steering wheel lock to lock.
As the wheel turns the large piston in the steering box will draw fluid from the reservoir through the pump, in the box, out to the cooler and out the return line to your drain pan, valves in the box keeps the fluid going in the same direction no matter witch way the piston is moving.
Keep the reservoir from emptying if air gets in it breaks the prime take a bit to get going again and will form foam.
13. When clean fluid starts coming out of the line reconnect the return line the reservoir, cycle lock to lock until the level the reservoir does not drop (air spaces replaced with fluid) and all foam settles out and stops circulating, this may take some waiting for the foam the settle between cyclings
14. Start engine cycle lock to lock, check for leaks.
15. Return to normal condition.
I prefer this to doing it with the engine running as with it running things happen very fast and it is almost impossible to keep the pump fed. Although running the pump dry for a short period is not likely to kill it, it is still counter productive IMHO.
HTH
Supplies:
3/8" barb
Small hose clamps
2-3 quarts of fluid
HTH
