Well since I'm sitting at the DMV waiting for a VIN inspection I thought I'd take this time to update where I've gotten the rig to.
Been posting in the 40 section regarding the head gasket/head replacement so now I'll throw everything up here to stay true to the 45 section and spare everyone the boring details!
I sourced 100% of my parts from Onur and his new business Land Cruiser Parts & Consulting LLC except for the cylinder head wich came from Torfab in WA.
New (to me) cylinder head, magnufluxed, cleaned, and pressure tested
I had all the head bolts and various other hardware that goes on or through the head cleaned up by my favorite machine shop. I was only concerned about the threads but they polished everything up and made it look purdy!
New OEM head gasket
New water pump to block gasket, discover the gasket that goes here
In between the water pump housing and back plate is NLA so I used some Toyota FIPG.
New thermostat housing to block gasket, new thermostat, new thermostat gaskets and new thermostat housing bolts. No pictures of these.
New studs and bolts that go from the exhaust manifold to the exhaust down pipe.
Remflex exhaust/intake manifold. Didn't do a darn thing to the face of the exhaust/intake manifold except clean off the old gasket and so far (about 200 miles) I've got zero exhaust leaks coming from the manifold.
New valve cover gasket.
New aftermarket coil (sourced this locally) as the OEM is NLA as far as I know.
Finagled a fuel line from the fuel pump to the carb but will eventually either create my own or find a used one.
I've re-torqued the head bolts 2 times in 200 miles and expect to do it again at 500 miles as well.
Made sure the plugs were gapped correctly, adjusted the timing to 7 BTDC, and she fired right up!! Blowing smoke like a SOB but who cares she's running!! I'll try and diagnose the smoke at a later time. Just gonna drive her for a bit and enjoy it.
