Proper Incline Gearing.....
North GA
Dropped down to second climbing a really steep (paved) side of a mountain today; took it out of OD as well.
What's everyone's take on the OD button on steep climbs? Out of OD and stay in D, or do as I did and no OD and drop down?
The steeper the climb the lower the gear. It's dependent upon the situation/hill. Some hills can be climbed in D. Other in Lo-L.
OD will be more apparent to you when you drive on the street.
Given the lack of power of the 1FZ-FE, disengaging OD is almost a prerequisite for any highway grade. On steep grades (especially at elevation) it is common to drop down to 2nd and sometimes 1st to maintain speed. I commonly cruise along at 4,000 rpm in 2nd when climbing mountain passes. A ScanGauge or UltraGauge is handy to keep an eye on temperatures. Read up on some towing threads for more advice on not getting passed by VW bugs on hills.
The lockup clutch in the torque converter will still engage in third gear as long as all the required conditions are met.
ie; engine coolant above 55C, speed above 60kmhr, throttle not at closed position,
Lockup conditions vary depending on whether the ECT switch is operated as well.
Cruise control also affects lockup of the torque converter.
This thread explains a bit more.
Explantion of transmission/overdrive behavior?
Sarmajor
I just drop it down to 2 or L and let the rpms fly! I do have the scan gauge to keep an eye on temps and would rather spin it up than bog down in D.
I drive her like I stole her, high RPMs and all.
Took her up the same pass today that stranded me a couple of months ago; pre modded blue fan clutch.
OD off and L....she made it up this time, yet was a little hot under the collar at the top. I contribute this to needing a new rad and fan shroud (foam is non existent). Right now my fan shroud just hangs there attached with 1 bolt.....flapping away.
Picking up the new shroud and rad this week though. Hopefully that will cool her down in steep climbs.
Planning a lot of adventures this Spring, so I have till then to get it sorted out. Not a lot of time :wrench::zilla:
LCP.....hear ya loud and clear :steer:
