I'm considering a new project for when I get back to BC (Less then 2 weeks!)
I'm thinking I might buy an 83 BJ60 5spd and swap the engine/trans/transfer/axles into my 1975 FJ40 (3F, 4spd, Drum Brakes).
What I want to do:
3B/H55 into the 40
Spring over with 60 Axles
Things I know I have to worry about:
Engine/Trans mounts
Cross member
Holes in the floor for shifters
Drive Shaft Lengths
Wiring
Cut and Turn/spring perches
Fender Flares (Adding approx 4 inches by swapping to 60 axles)
Things I don't know:
Clutch/Brake masters (Do I need to swap these)
Steering Column Differences (non-PS to PS)
Wiring - How much do I need to change for the 3b from my original wiring for the 2F
Anyway I've been doing lots of reading on mud... and have a lot more to do but does anyone have any wise words of advice?
The plan right now is I would do this in stages:
1. Get the 60/Part it out
2. Put Engine/trans/transfer case into my 40
3. Do cut/turn/spring perches on the 60 axles
4. Mount axles/PS for spring over
Does any of this sound reasonable or am I insane?
What I want to do:
3B/H55 into the 40
Engine/Trans mounts
Cross member
Drive Shaft Lengths
Wiring
