Project flintknapper
65swb45
Elder Statesman
Website
marksoffroad.net
If you’ve never heard the word before, it’s the process of chipping at obsidian or any other object to make an arrowhead or cutting tool. Lots of tiny taps.
Sooo, I got a very small box in the mail last week. Was supposed to be a carburetor, but it was too small. Turns out it was 2/3rds of an SD40, minus the base! Huh? Anyways, a very small box.
Got the SD26.6 out of the box and had a WTF moment. I’ve never seen anyone knap a carburetor before!
The carb was obviously badly warped, but the ‘solution ‘ was worse then the problem! It looks like they literally tried to fold the air horn over the fuel bowl.
And they partially caved in the pocket of the air horn where the accelerator pump arm sits, in what I can only guess was a very misguided effort to get the pump to work.
The reason the pump wouldn’t work was because it was plugged up with the same spooge (some variant of sea foam no doubt) that was bonded to the fuel bowl. :rolleyes:
Now that’s definitely one for the wall. I have a few with the air hole drilled in them but none that look like tenderized meat.
Well, for as much as it was wall-worthy, the customer REALLY wanted me to try and rehabilitate it. Why? The picture tells all.
Beautiful. Is that NOS bowl glass?
No, it’s actually the 56 year old original glass. For the beating it literally took, it is a lo-mileage core. I was just telling the customer this afternoon that the throttle shaft is still tight in the throttle body, and the linkage between the throttle and the accel pump actuator is not ovaled out like most are.
The real culprit here was that a previous rebuilder did not pay good attention to the parts in the kit, and they obviously got ahold of a Keyster kit with the 64-66 metering rod. That rod has the exact opposite look AND EFFECT of the 63 and older metering rod, which is what this 63 carb needed.
I had to pull the correct metering rod out of my super-secret stash to make this carb complete.
It also had a 2bbl brass float of unknown origin in it which I replaced with an NOS 1bbl float.
Unreal, great work! I want a SD40 just as a desk ornament.
