This site may earn a commission from merchant affiliate links, including eBay, Amazon, Skimlinks, and others.
rock scientist..
Staff member
s-Moderator
Moderator
update?? The tranny started to puke fluid out of it last wed night.
Looks like the C6 is coming out for an AOD.
"Hallucinations are bad enough. But after awhile you learn to cope with things like seeing your dead grandmother crawling up your leg with a knife in her teeth. Most acid fanciers can handle this sort of thing. But nobody can handle that other trip-the possibility that any freak with $1.98 can walk into the Circus-Circus and suddenly appear in the sky over downtown Las Vegas twelve times the size of God, howling anything that comes into his head. No, this is not a good town for psychedelic drugs."
Rescuer of Beagles & Landcruisers
Moderator
Where you too hard on it or was it time for the C6 to go?
rock scientist..
Staff member
s-Moderator
Moderator
I think I installed the wrong flexplate.. If you get the wrong one, it alters how far the TC enters the pump and either bottoms it out or does not engage fully. And apparently, That eats up the pump pretty fast.
C6's came behind big blocks and are stupid strong tranny's. The AOD is a step backwards in strength, however I don't feel I really need the strength of the C6 and I REALLY want a lockup torque converter and an overdrive to try to get a bit more mileage out of Bob.. Plus the C6 eats a stupid amount of power (~60 hp at least). So with a reasonably built AOD I should have better mileage and more power getting to the ground.
I have been itching to replace the C6 since I put it in and hit 3K at 65 on 35's and 4.11 gears.. I built this as a driveing truck, not a crawler. If it was a crawler and I was going to be putting it in stupid places all the time, I would stick to the C6..
One cool thing, the mounts for an AOD and C6 are almost in the exact same spots.. So it is almost a bolt up affair... Or so I am told
Supporting Vendor
I
Mace....thanks for the Chipotle....
Moderator
rock scientist..
Staff member
s-Moderator
Moderator
Ford's non electronic controled OD auto tranny like Dan said.
It had some problems out of the gate (as did the 700R4) but the aftermarket has stepped up and taken care of things.. A good chunk of the issues have derrived from not having the TV cable adjusted properly..
rock scientist..
Staff member
s-Moderator
Moderator
Lovin the AOD.
I went from 3K rpm at 65 mph to 1900 at 65 mph.. The truck is now MUCH quieter while driving and appears to be getting slightly better mileage (13 maybe??)
Moderator
Wow, that's a difference. Bob get painted yet?
rock scientist..
Staff member
s-Moderator
Moderator
yep, lock up torque converter and an overdrive is niiiicccceeee...
no paint yet. I need to get on that one of these days lol
Lovin the AOD.
Do you have enough power to pull a grade at 65mph and 1900rpm?
1994 Land Cruiser, 1974 Land Cruiser
rock scientist..
Staff member
s-Moderator
Moderator
Depends on the grade.. I can always down shift out of overdrive too
Just wondering. It's annoying to me to have an auto tranny shift down on a slight grade when I have the cruise control on. I guess you don't have to worry about having the cruise control on, though do you?
rock scientist..
Staff member
s-Moderator
Moderator
lol
Not yet, but I do want the cruise ability
Honestly it pulls pretty well even at 1900 rpm. But if I give it any gas, it downshifts..
rock scientist..
Staff member
s-Moderator
Moderator
I have one, but there is no way I would use it for a cruiser control..
I'd rather get one of the aftermarket cruise controls out there. They actually work pretty well..
You could always throw in some lower gears and get your cruising rpm around 2500...
rock scientist..
Staff member
s-Moderator
Moderator
That may happen at a later date, as it stands, 75 mph is about 2200 or so and I am enjoying it.
