sJs said:Another quick question: after installing the OME Tbars, how much did you have to crank (if any) for 2" gain you recorded? Also, how stiff was your ride with the OME heavy suspension before adding major weight like the bumpers?
bull said:Front bumper madness!! I want to stuff a 12K Warn in there..but don't know if it will fit..
4.88s and ARB up front
Some other goodies.
bull-- seriously, how does it drive on road with the lift and 315s?johnroyale said:bull-- your rig is very cool!...As you have it built up now how does it drive on pavement?
johnroyale said:bull-- seriously, how does it drive on road with the lift and 315s?
I was hoping you wouldn't say that, now I HAVE to strongly consider the same setup.bull said:It handles the same and is more tight around corners. I also noticed the ride is a bit stiffer from cranking the torsion bars, but not bad..overall I'm happy with the pimp ride..
ats4x4dotcom said:The torsion bars are the same tension no matter where the adjuster is, the adjuster just determines the height the vehicle sits at, in relation to the amount of torsional strength in the torsion bar.
Adjuster is like adding a coil spacer to a coil spring, no rate change, just different height.
bull said:It was a figure of speech..
I believe if you adjust your torsion bars too much it will affect the ride of the vehicle by limiting the droop of the front tires (and that is what I'm talking about); Thus giving you a stiffer ride. At least that is my experience with other IFS set ups I have come in contact with.
ats4x4dotcom said:Wont give you a stiffer ride, will just make the wheel hang in the air as the shock tops out, if you dont have enough droop but there is no weight on that wheel when it does so, so it doesnt 'effect" the vehicle ride as such.
Same as adding coil spacers wont chnage the ride, it just makes the car sit in a different orientation between bump stop and topped out, but it doesnt make the suspension work any differently otherwise.
bull said:So what you are saying is the ride "feel" won't change if I raise the front of my vehicle via the torsion bars?![]()
ShottsUZJ100 said:Bull: You and I both are on the same page. While ATS says "no rate change" and he's correct, his statement's also misleading. I remember getting jumped on about misleading statements from forum members?![]()
A T-Bar is progressive. The more you twist it, the harder it gets to twist. When you lower the lower arms to lift the vehicle you demand the bar to twist more than it's meant to before the bump stop stops it. That means at more of your upward travel range, especially the latter half, the spring-rate is higher than it should be and therefore the rate is stiffer and therefore your ride is stiffer also.(And that more force is required to flex-out or stuff the front wheel off-road)
