Productive Christmas!
Columbia, SC
I put my 55 rear springs on with my custom shackles. The rear actually moves up and down now when I push on it.
And I put my rear disk brakes on using Posers bracket. Definately cleans up the rear.
I started on the front, but if you have seen my other thread I have encountered a little problem with the front spring hangers.
Hawk, here is a full body shot in its current state.
Awaiting delivery of Longs, studs (hub/knuckle), and steering arms to put the front axle back on.
Thanks Cruisen, I got the u-bolts from man-a-free. They had the best deal at the time. Came with one long one too.
Thanks Hawk, I got the springs from m3tal dork on here. He shipped them from Utah. The shipping was more than the springs, but was still a good deal.
Jeremy
Dam that's a lot of arch, see if you can flatten it out a bit and see where the shackle resides..
Throw some weight in the back... The springs will settle over time till they are about flat anyway..
I am thinking that those shackles will stick WAY out when the springs are flat..
Which may not be a bad thing..
I have to cut off my rear crossmember and mount my rear bumber in place of it. The rear has a little rust on it so I am going to rebuild it. At that time I will take the rear hanger off and make adjustments if I need to.
I can push down on the rear and it will flex, taking a few leafs out might be a good idea though. I will be taking the rear apart again later. When I do that I will take them apart and paint them and put longer spring pins in.
I already have greasable spring pins in the front of the rear springs and the bolts in the shackles are greasable bolts.
I am trying to get it back together the best I can so I can paint it. Small things that won't affect the body I will fix later. Like painting the axles and replacing every brake line and rewiring the whole thing.
Thanks for all the comments guys, all of you have been a lot help. From all the research and technical links on this website to all the quick imformative responses that you guys give.:)
Jeremy
looks cool man. You have a group on that side of the state you ride with?
I'm confused, can you mount longer springs without mods? Those spring mounts look like they're in the stock locations, are you planning on moving the rear mount? Are you just using an extended shackle to make up the difference?
Forgive my ignorence.
https://forum.ih8mud.com/showthread.php?t=70839
VTFJ40, here is a link on how I mounted them.
89's Rule, no I do not have a club near me. There is a club called the Carolina Crawlers I think. But they are mostly jeeps. My brothers all have TJ's and YJ's so I guess I am a cruiser man trapped in a jeep world. Let me know of any cruisers I could meet up with. I will be going to Spartenburg when this gets finished, then to Jellico, and Tellico. My brother is in WE-ROCK with his TJ this year. So we will be going to all of those comps., and practicing up at Tellico and Spartenburg, maybe at that new park that opened.
Hawkdriver, what do you mean I have your name.
Jeremy
Jeremy
I am not a member yet, but the Upstate Cruisers are who I deal with the most. They have a board in the club section on here. Most of the guys are from Clemson or around Greenville area. They have members from all over. And have several people who are from farther away.
Check out the boards for them on here. They are getting together for Tellico for MLK weekend. And I hope to head up that way with them for GSMTR this year.
I dont make it over your way much anymore. My step dad's fam is from FLorence so thats about as far over as we ever get.
Please, correct me if I'm wrong but; what is the thickness on those shackle plates? By the looks of your pics I would guess about 1/8 inch. Just seems a little thin to me.
