55 springs on a 40
Seattle
I scored a good deal on some 55 (atleast I was told they are) springs this summer. I am working on a SOA and I am planning on throwing the 55 springs on. I noticed that the sping eyelets are quite a bit larger than the stock 40 springs. Any recommendations on how to deal with this? Would it be a bad thing if I use some tubing to make a sleeve for the shackle and pin bolts to fit the rubber grommets? Or is it necessary to modify the hanger and look for a larger pin.
Do the 55 spring have a larger pin or am I the sucker in a bait and switch...
What have other guys done?
Thanks
Sucker!!!
Now send me the rear springs from that 55...my 40, uh 55 could use them.
If you are going to use them then you will need to move the rear shackle back. Its actually a very nice mod for a 40. If you decide you don't want the springs I'll trade you for a set of 2.5in lift springs that are currently on my 40.
I got a set of bushings that would fit the 55 springs and then drilled them out to fit my stock sized 40 spring pins. Thay are 15mm greasable spring pins so I got a bushing that had a smaller I.D. to fit the 55's and then took a 19/32 drill bit (closest to 15mm) and drilled them out. was able to keep all my stock 40 stuff, spring pins and shackles.
And yes, you can flip the rear spring hanger or use a shackle that is about 2 1/2" longer than stock.:)
Thanks. Good idea Belmont. I'll see what I can find for bushings. I have already removed the hangers and plan on flipping them.
Drohweder, nice try! I'll keep 'em for now.
Andy
Here is a copy of my recent order to put my 55 rears on:
289-55-A 4 55 Series S-O-R Poly Bushing-Black gr $6.72
289-55-C 4 55 Series S-O-R Poly Bushing-Black gr $6.72
289-40-C 4 40 Series S-O-R Poly Bushing-Black gr $6.68
288-89 2 Greasable Shackle Bolts-Fits #288-80 $33.30
The bolts will be used to make my own shackles, and no modifications will be done to the bushings that go onto them (289-55-C for the 55's and 289-40-C for the 40 spring hanger). The 289-55-A bushings will be reamed out with the 19/32 drill bit I just bought. Those should slide onto my stock greasable spring pins, and everything will be able to be greased easily.
I will let you know if I have any problems putting this together.
Maybe this will help others out because I could not find any tech stating an exact way to do this. Just fague statements like "play with different bushings and see what happens.":beer:
