Product Update: Water Pumps & Thermostats
cruiseroutfit
Supporting Vendor
Moderator
Utah
Website
cruiseroutfitters.com
Got the cooling system blues? Our stock of high quality Japanese aftermarket and OEM Toyota water pumps and thermostats are on the rise and we are filling gaps in our inventory. We now stock the majority of F Series engine applications as well as the B and H diesels as well. Give us a ring at the shop if your in need of a pump or thermostat!
High quality 'Made in Japan' water pumps and thermostats:
@cruiseroutfit
I need a water pump and gasket for a '86 2F.. REMOVED THE OIL COOLER and prefer not to block off the old oil cooler port.
What ya got?
Jason
We should be able to accommodate that. Thinking the EGW61070 would do the trick. Gimme a shout and I can check with them side by side and make sure everything matches except the lack of oil cooler port.
Kurt, It was great to talk to you again. Thanks for the great service and price on the parts.
Jason
UPDATE:
We now have a full selection of AISIN, OEM Toyota and other Japanese manufacture water pumps, thermostat and gaskets for the F, 2F, 3FE, 1FZ, 2UZ and 3UR gasoline motors as well as the 3B/13BT, 2H/12HT and 1HZ/1HD applications. Give us a shout if your Cruiser has some cooling woes!
Latest water pump offerings, all in-stock:
(High Quality OEM & Japanese Pumps)
Part# EGW60080OEM (Fits 69'-1/75' FJ40/55)- DISCONTINUED
Part# EGW61012 (Fits 1/75'-8/76 2F W/O Oil Cool or Fan Clutch, FJ4x/5x Fed. Spec)- $105.50
Part# EGW61012OEM (Fits 1/75'-8/76 2F W/O Oil Cool or Fan Clutch FJ4x/5x)- $190.50
Part# EGW61041 (Fits 8/76-1/79 2F W/Oil Cool, W/O Fan Clutch, AISIN) - $107.50
Part# EGW61070 (Fits 8/76'-1/79' 2F W/Out Oil Cooler) - $105.50
Part# EGW61081 (Fits 1/79'-7/87' 2F W/Oil Cooler, AISIN) - $107.50
Part# EGW61081OEM (Fits 1/79'-7/87' 2F W/Oil Cooler, OEM Toyota) - $125.50
Part# EGW61180 (Fits 8/87'-1/90' FJ62, AISIN) - $107.50
Part# EGW61180OEM (Fits 8/87'-1/90' FJ62, OEM Toyota) - $209.50
Part# EGW69235 (Fits 8/1992-12/1997 FZJ80, AISIN) - $87.50
Part# EGW59275 (Fits 1998-2007 UZJ100, AISIN) - $105.50
Part# EGW09491 (Fits 2008-15 URJ200, AISIN) - $105.50
Part# EGW59105OEM (Fits 3B/13BT Engine, BJ7x, with Fan Clutch, OEM) - $167.50
Part# EGW59105 (Fits 3B/13BT Engine, BJ7x, with Fan Clutch, AISIN) $107.50
Part# EGW59076 (Fits 3B/13BT Engine, BJ7x, without Fan Clutch, AISIN) $87.50Part# EGW69015 (Cover/Rotor Assembly, 2H/12HT Disease Applications, AISIN) $87.50
Part# EGW69037 (2H/12HT Diesel Applications, OEM Toyota) $230.50Part# EGW19235 (Fits 1HZ/1HD/1PZJ 7x/8x/10x Diesel Applications) $97.50
We have a few more not shown including 1HZ/1HD with or without timing belt kits :cool:
Nope but I have a pallet (literally) of BJ60 water pumps to add to our system and get online. Ring us when you're ready!
Summer Heat Special: Buy any water pump and any fan clutch and you will receive 10% off at time of order :cool:
We also stock hoses, thermostats, fans and belts. Clean up your cooling system with a single call.
