problems with my '97....
I have a '97 Lx450 and a couple of wierd things haave been goin on with it...
A couple of weeks ago my antenna stopped going up and down but i can still hear the motor that normally pulls it down or pushes it up running after i turn the car off?
also, my back left window motor is going out and i was wondering if anyone has plans or diagrams for door panel disassembly?
any idea where i could get schematics of the antenna area?
Get the FSM. It's worth it.
What makes you think your window motor is going out?
when i push the button down the window goes down just fine.... (gravity?)
but when i pull the switch for it to roll up it either does not respond or goes up half an inch or less and gives out.(although on rare occasions it has gone up a couple of inches by itself)
Antenna mast replacement is in order. See here --> Power Antenna Mast Replacement
If you can get the old mast out then replacement of the mast shouldn't take more than 15-30 minutes. If you can't and have to pull the antenna motor then it will take considerably longer and the job is much more of a PITA.
On the window...For me the only thing that resolved the problem was a new motor. Get the FSM from Toyota...Well worth the $$ although IIRC it is a little lacking in stuff like door panel removal but it will help. Otherwise, I'm sure there are many posts out there with pictures.
Look into new window runs too. You can take a clean rag with soapy water and clean out the inside of the window run (the rubber gasket where the window sits) and see if that makes it easier for the window to move up/down. When I did that on the :princess: rig, the window went up much easier for a while (the rag was pretty well blackened by the time I was done cleaning it).
That was a temporary fix until I could replace the window run itself. If yours has never been replaced, it probably needs to be regardless. But clean it and if it makes a difference, you've likely found your culprit.
