Probably a stupid question, but...
DFW & Durango
What is this "button" under the dash? Google and Haines are failing me.
^^ what he said.
For handicapped applications?
More for keeping engine idle up, to cope with increased loads like winching, etc. It's also useful if you're running a manual trans and doing a lot of technical trails/crawling. You can lock the throttle at "X" RPMs, and then your feet are free to work clutch & brake pedals as needed. At least this is my understanding.
Or when running an air compressor to keep engine RPMs up.
Years ago I used that spot to mount a toggle switch for an auxiliary pusher fan.
It looks like it needs a switch.
So for those of us who winch, can we get a little lever/puller on that thing to actually use it?
You can still purchase the toyota hand throttle cable. It's about $50 and you can find it a bit cheaper elsewhere. I look forward to having mine installed.
Paralyzed waist down. Need hand controls. Something like that. Some vets at my gym have hand controls.
Ok, I see. I asked because my son has cerebral palsy and we've been discussing what it would take for him to drive.
Different kind of throttle control.
Yep...stupid question...you were right. Give him a sticker someone! Just kidding, but seriously, that's not a half bad idea, using the stock hand throttle hole to adapt handicapped hand throttle to an 80.
Somebody did awhile back IIRC - had a old bicycle brake lever/friction shifter & extra long cable & cable housing, mounted to the shifter arm.
Someone broke their R leg & used that setup.
I remember it because I'd broke my L leg & wasn't driving for awhile myself.
I use the normal hand throttle & my winch never kills my single battery, for those looking to avoid dual battery setups esp with an eye to winching.
I think you'd find it in a none too convenient location.
I used mine occasionally as a "cruise control" on long drives inter-state when sitting on constant highway speeds for 100s of km at a time in a manual 80 with no cruise control. Gotta keep a really good eye on traffic ahead of you
I wasn't suggesting using the factory hand throttle, but that the 80 is almost factory equipped to accept handicapped mods because it has the hand throttle hole and mounting points. I will mount my factory hand throttle this summer when I do my motor swap, the accelerator pedal needs the mounting point for the cable so I will weld one on this summer while the 80 is gutted.
^^^Your gas pedal arm should have the pick point already, I think.
I was just under the dash ~couple weeks back looking to replicate the hand throttle situation for my Tundra, the spot on the arm was a factory install even to NA 80 models.
Unless '93 is some 'nope, not then' thing. IDK.
On a '97 it's not even a 1 :beer: job if you start with the cable & not with popping the cap/tab.
Srsly, a 3 minute install.
