Preventative Maintenance
Lake Jackson, TX
Hey y'all,
So, I am slowly pouring more and more of my paycheck into my TLC. :)
What are some things that I can do as preventatives, in the hopes of saving me some cash down the road?
Little things now = big things later.
Things specific to the Cruisers or just general vehicles. (I'm only 20, with 3 years driving experience. I have mechanical knowledge, but all of that is on boat engines.)
Three things that can cause the most headaches: belts, coolant hoses and vacuum hoses. All are challenging in their own way but once you do those you can cross them off your list for years. Then work your way to brakes and axles.
Keep an eye on wheel bearing preload especially with larger than stock tired. Loose bearings will lead to damaged spindles and much expense, ask me how I know...
Don't forget to thoroughly wash your underbody and grease prop shafts and other grease points regularly if you have a tendency to play in mud.
I'm sure others have more ideas.
Any and all cooling hoses(PHH, and the rest of the likes)
flush the cooling system
t-stat
heater control valve
Fresh fluids(engine, trans, diffs, tcase, coolant)
You have come to the right place, the folks here amazing and full of info...and always happy to help!
Ps the search function will unlock loads of info instantly too.
All of the above, plus radiator and electrics. The radiators on these are a time limited item, and will fail sooner or later. Make sure yours is in good condition/replace it with new.
Get into all your body panels, pull your connections apart (without breaking them, but the FSM shows how) clean them and put some dielectric grease on them. Disassemble all your grounds, remove any corrosion, and put dielectric grease on them.
If you wheel at all, put sliders/rails on it and replace that crappy trans skid plate with something better.
And, oh yeah, get some kind of way to reach into your engine compartment without putting your body weight on something expensive that can break. The radiator nipple, fan shroud, fuse box, accelerator cable and air hose are relatively fragile, and if you lean on them, or hit them when you slip and fall off whatever cobbled together Rube Goldberg device you've rigged to get up there, it's the same as if they failed for lack of maintenance.
I just bought a Tire Step.
Thermostat was my first bit of PM. Ditto all the belts, and don't be afraid to crack open your dash and clean out the compartment behind the radio and glove box. Plugs and wires (I stuck with Densos) and new radiator upper/lower hoses. Check your alternator.
Buy a Field Service Manual too so you're not flying blind. ;)
1992 Toyota Land Cruiser Shop Manual 92 Original OEM Repair Service Book
Also Check your axle seals for leaks (look for obvious grease buildup on the inside of your rims), and do a code check to see if your truck comp. is throwing any codes. If it's OBD1 you'll need to do the paperclip trick.
I'm 24 bro with very little mechanical experience, but the great guys on this site have provided me an amazing wealth of knowledge. Couple that with the FSM and my dad's help (who's building an FJ40 himself), there's no job you can't at least try.
Have a Mud Sticker?
Change Diff Gear Oil and get new Allen Head Plugs (Dealership)
Wires (NGK), Plugs (Dealership) and PCV (Dealership), PCV Grommet (Ebay), Cap (Ebay from Japan, Rotor (Ebay)
Is Power Steering Pump Leaking?
Chk Condition of Coolant Bypass Valve in Engine Compartment on Firewall
Grease U- Joints (Do not over do it)
Check Brakes for Wear, Check Tires for even wear
Run Hand Around Exhaust System when it's cold and running feeling for air leaks
How Old is Battery? Unknown then test
How Old is Coolant? Unknown, then change
Replace Hoses (Gates or OEM)
Replace Belts (Gates or OEM) Do not get Cogged Belts
Windows go up smoothly? Replace Runners if not.
Replace Tranny Fluid with Synthetic
Upgrade Headlights to HIR or LED
Check Grease Level in Knuckles
Add a Cupholder that will fit a tall boy (you are young) for when it's parked of course.
Front and Rear Bumpers, Sliders, and Roof Top Tent.
Get a girl that likes to Wheel and dad that owns a Gas Station.
Well that outta keep you busy for awhile.
You are base lining a vehicle that is at least 19 years old, it'll take some time and money.
If you have access to a place to have the underside and engine compartment steam cleaned, do it. Lots of big rig shops can do it for you. If not use something like Simple Green and pressure wash. Being able to clearly see everything and have all gunk gone when you do turn wrenches makes a HUGE difference.
Once dry park over a clean driveway or garage or throw down some cardboard under the truck over night or longer, that'll show you where to look for leaks.
Go through the truck and spray Liquid Wrench or similar on all bolts you will be working on in the coming months. Spray them once a week or so for a few applications.
Enjoy :)
before you buy anything search / ask what you can cheap out on (rock auto) and what you need to spend the extra cheddar on for OEM Toyota parts.
There are various items that MUST be OEM on these rigs or they will function poorly.
Do you guys recommend oem or aftermarket for the egr vacuum modulator?
Cruiserdan might be a better option as he is in AZ and Beno is in Georgia if I remember.
Not sure CDan is still in the game.
You can also call Beno at 505-944-5081 and discuss your problem and needs.
The same for Dan at 1-800-432-6668 x 8.
Good stuff here ! I'm a new owner also and wondered what all I needed to address first.
Got a buddy to put it on a lift and found all kinds of exhaust system issues ( old crap repairs that have failed ) so that's the first thing up.For some reason I'm not a fan of Carbon Monoxide in the drivers compartment , lol.
Im looking forward to getting this truck back in some kind of shape -
