Preparing for the Dusy...what do I need?
Carpinteria, CA
I'll be running Dusy Ershim next month in my 80 and was looking for some suggestions on how to best prepare my rig and what tools/spare parts to bring.
Here's what I'm working with right now:
1997 80
Aussie rear locker, open front
2.5" OME w 1" spacers
295/75/16 BFG AT's
Metal tech sliders
Slee transfer case skid plate
ARB front bumper
12k winch
Anyway, I appreciate the help. I know it will be a challenge and I'm ok with a few scars but want to as prepared as possible. As always...thanks in advance.
Paul
I'm ahead on all maintenance and do it all myself after seeing what lackadaisical mechanics do.
My preparation for any long trip is as follows:
1. Pack cooler
2. Put the cooler in the LC, start'er'up and leave.
IMHO, YMMV
1. Pack cooler
IMHO, YMMV
All good on maintenance. I might put new oil in the fan clutch. I've done the cooling system along with the phh as well. Also, rebuilt front and rear axles(birfs, seals etc done at slee)
Sounds like your good to go dude. Don't forget to check your belts, you don't want to get sidelined by one of those coming apart.
Belts are pretty new plus I've got some trail spares.
What I brought when I did it:
1. PS gear box
2. front and rear driveshafts.
3. front axles and birfs
4. rear axle shafts
5. tie rod/relay rod and ends.
6. hoses, belts, EFI components.
7. one front hub/bearings/ greased ready to go.
8. rear hub/bearings/greased ready to go.
9. knuckle studs
10. hub studs
11. front axle rebuild parts.
12. gear oil and grease.
1. PS gear box
4. rear axle shafts
9. knuckle studs
10. hub studs
Of which he used only #13. beer :flipoff2:
1. PS gear box
4. rear axle shafts
9. knuckle studs
10. hub studs
Wow Onur!!! I know I won't be able to gather all of that before the trip. I'll get what I can though.
Thanks
I haven't run it, but I've heard the Dusy isn't unusually difficult, just sort of relentless. Instead of beer, pack a bunch of energy drinks and then you'll stay on your game. I recommend Rockstar's Silver Ice
the thing about the dusy is that it is remote, real remote. If you are running it front to back then you will be a long ways out if you don't have the spare parts you need. Definetly bring spare birf and simple stuff like fuses, belts, hoses, etc. I am guessing you are running it with other people, a good group always ensures safety.
I carry alternator, starter, water pump, belts, hoses. Think about the things that will absolutely strand you. Many things you can get by without or fix (ie: sway bar or a damaged radiator). If you lose your water pump, you are done. If you poke a hole in your radiator, you can remove, use pliers to pinch and pour in some bars leak. Usually catastrophic failure of the OEM engine is rare, that is if it has been properly maintained.
We ran it in October and saw not one other car for 6 days. It may be different is August, I don't know. We got snow and very cold temps so be prepared for that. Bring a fish pole for dusy lake.
Fyi, it is a VERY tight trail. Those fender flares are going to get damaged or torn off.
My fj40 broke down 2 miles from the end of the trail. Turns out the fuel injection system completely shut down on my vortec, catastrophic failure. I had 80's pull me through to the end of the trial via strap with tires pumped to 35psi, snow, pitch dark, using a headlamp as a headlight. It was scary as hell and I never want to do that again.
So, that is one of the reasons I ended up selling my 40 and am now building up my dream 80.
My point to that is to give you comfort in the fact that you are taking the right vehicle for the job.
Have a kickass time, just a fantastic trail. FYI, don't do it quick, take your time. Dusy lake was so beautiful our party just decided right then to stop and take an extra day.
Noah
Think I should deflare before?
Well be taking 5 days to do the trail and well be fishing as well
^^^ What Noah said.
Paul: Contact Cruiserdrew on MUD as well. He has been running the Dusy for years and knows it like the back of his hands. He can tell you all sorts of stories about what can go wrong on the Dusy and make for a very bad, bad trip.
up to you, I would, just because it may be possible for the plastic flares to cause more damage. They will get cracked and will just be a PIA to deal with on the trail. Some spots on the trail are literally squeezing through between 2 trees, very tight. Just be prepared for some scratches for sure, maybe a dent or 2 and have fun!
1. PS gear box
4. rear axle shafts
9. knuckle studs
10. hub studs
What he didn't bring but was glad someone else brought: welder. :flipoff2:
Note that cell phone service is extremely limited and only available in a couple spots. So if you break down and need to call a buddy to bring spare parts it may be a long walk and even longer wait. Also elevation starts around 8,500' and is mostly in the 9-10K range, so it definitely gets cold at night and can see extreme weather. But it's fun and has some breathtaking scenery.
That's a good looking 80!
You have time to add a front locker-I would do that for Thompson Hill. You don't have a lot of lift or very big tires so stack the odds in your favor in other ways. Put the most capable truck in your group in front on Thompson so you will have something to winch to. My bias is that I hate Aussie type lockers, because the load /unload thing fatigues and breaks the hub studs. Check them like religion for looseness every time you stop. Check your knuckle studs at lunch and at the end of each day.
Spares: Bring what you have. We have needed axles, knuckle studs, wheelbearings, hub studs, spare tires, many fuses, belts, hoses etc. You are a long, long way from help there so be prepared for the common failures. A spare tie rod with ends is a very good spare to take.
I had never heard of a broken steering box, until we did Dusy and now I always carry one. I've seen a bunch of broken 80 steering boxes since-the sector shaft fails at the splines. We had to order a spare box by sat phone, and limp the truck to the exit where the replacement box was brought from Sacramento.
I seriously had an engine fire there that burned up my wiring harness-in the middle of Thompson Hill. To say it sucked is like saying it's cold in Siberia in January. It took a full afternoon to connect enough wires to continue.
Bring a snatch block for your winch-useful for triangulated pulls-like righting a vehicle-we've had to do that too.
Rear driveshaft-definitely bring an extra. This trail will likely barber pole yours so it's nice to have a clean one to get home without vibration.
Leave your roof rack home.
A chain saw is nice to have if fires are legal. One year a log had fallen across the trail since the last people had been through. It took several hours to make a path around. A chain saw could have done that in 15 minutes.
Make sure your tow points front and rear are solid. Have recovery gear, shackles straps, etc in every truck-in the front seat.
Remove your front sway bar at the start of the trail-trust me on this.
This is the only trail I have ever done where a High Lift was the only thing that was going to solve our problem. Bring a 60 incher.
Take the plastic wings off your rear bumper. Same goes for your center caps. Leave them home.
The people that say this trail is easier than Rubicon usually have never done either. It may be over all just slightly easier, but it is 3 times as long, 3000 feet higher, and mental fatigue is a real issue. Let up your guard for 3 seconds-you will have a problem. Do not underestimate this trail.
You sure you don't want to just go to Pismo?
