Preparing For Front Axle Rebuild
Cortez, Colorado
I have a 1997 LC that I have owned for 2 years and it is my daily driver.
I finally noticed some grease oozing from the DS knuckle and am going to attempt what I should have done sooner, the front axle rebuild.
I have read and printed the FAQ and have ordered:
- the FSM (not here yet) FED-EX can't find me
- the front-end kit, new rotors, 100-series pads, and new
Koyo wheel bearings (arrived quickley via CDan & UPS)
- 54 mm Hub-Socket from Slee (very fast, received
the very next day) UPS CAN find me
I went through the pick list for all of the parts and I have a few that were not bagged, or bagged with something else, and I just want to make sure I know what they are. I am fairly certain that I have everything, in that I have something that corresponds with every-item on the pick-list. First I am going to list the #number and the description for the item that I am unsure (I have guesses, but would like to know for sure) what they are, then a picture of the items. The items in the first picture with a red circle around them were all in the same bag as the Lock Washers to their left. If anyone out there can help me match them up, that would be great.
Thanks,
Part # Description
12157-10010 Gasket, DR
43422-60060 Gasket, FR
90520-31007 Ring, Snap
90521-34005 Ring, Hole
43436-60011 Gasket, KN (this description is exactly the same as
a bagged item with #43435-60020)
Thanks,
Part # Description
12157-10010=diff drain plug gaskets (do not reuse the old ones)
90520-31007= snap rings that go on the outermost part of the axle, in a nice grooved valley at the end of the shaft facing out.
90521-34005=these snap-rings go inside of your birfield housing and keep the axle end inside of the birfield housing. You will need these if you decide to take the axle shaft out of the birfield housing and take the birfield housing apart for either swapping or cleaning.
43436-60011=gasket that goes between spindle and birfield housing
43422-60060=flange gasket for the outer hub area.
Mainly, make sure you replace items from where they came out of...
Dan's packer should be doing a better job of differentiating parts...:flipoff2:
pl
Here's something that I found to be very valuable: Print the page from the FAQ front axle rebuild thread in which Dan lists all of the torque values. You will need them one after the other and you don't want to be thumbing through your nice, new FSM with greasy paws. IIRC he might have left out one or two, so you'll want to fill in the blanks, so to speak.
Good luck:wrench::cheers:
This will be a messy job, but take your time to do it. Make sure you have plenty of towels, a large piece of plastic sheet that will cover your working area. I used a big plastic container filled with heavy duty cleaning solution to clean up the birfield too.
Speaking of torque values, I do not yet own a torque wrench and am looking to buy one. I noticed that some of the values are in inch-pounds. Does this require a separate wrench?
Another issue that is frightening the :censor: out of me is this whole adjusting the pre-load thing.
Needless to say, I am a newbie and this will be, by far, the most involved process that I have ever attempted on a vehicle. I would not even be attempting this without all of the collective wisdom shared on this site.
I am trying to plan this thing out the best I can. I should have 4 days to get it done, but would like to have all supplies, tools, parts ect on hand and prepare for the worst.
Thanks to those that have posted and to all of those who might offer any more advice, tips, warnings etc.
You got it, I did it and am a super novice mechanic. It took me 16 hours, broken into 2 days. Ditto on this site being a huge resource for land cruiser DIY'ers. Good luck!
joel
One thing's for sure, you're going to need a torque wrench in inch pounds AND foot pounds if you want to do this right. I am in the middle of my first axle service right now and I cannot imagine doing it without torque wrenches. I borrowed three wrenches from a good friend, and they have been very useful. It is good to have the peace of mind that everything is put back together correctly. I am getting ready to set pre-load tomorrow, and it is scaring the crap out of me. I bought a fish scale to use, as the "feel" approach is meaningless to me due to my lack of experience. I hope someone else chimes in because I could use the help also.
One word of encouragement is, the job is not technically difficult. Get a brass drift punch or two for removing cone washers and removing/seating bearing races. Take your time while removing things, even taking pictures as you go, and you'll see how it all fits together. it will be clear to you where all the respective parts/seals/gaskets go. Don't over torque the six small bolts that retain the knuckle wipers. A well meaning friend of mine that was helping me, already snapped one off. There are no torque values listed for these in the FSM. So just get them snug.
That's all I can think of right now.
Happy wrenching, and don't forget step six! :beer: :hillbilly:
Speaking of torque values, I do not yet own a torque wrench and am looking to buy one. I noticed that some of the values are in inch-pounds. Does this require a separate wrench?.
Inch-pounds = foot-pounds x 12
i.e. 120 inch-pound is 10 foot-pounds
You can get away with one torque wrench if it has a broad enough range, but 2 will serve you better. I have one 3/8" drive that does up to 80 foot-pounds, and one 1/4" drive that does up to 200 inch-pounds (17 foot-pounds).
I don't like the Toyota method of adjusting the wheel bearing preload with the spring gauge. For years I have used Jack Alford's method posted on off-road.com for mini-trucks. If you want, you can adjust the bearings using Jack's method and then double-check it with the spring gauge.
Toyota 4x4 Front Wheel Bearing Servicing/Replacement - - Toyota at Off-Road.com
I also recommend having a helper that has done the job before so you can get done much quicker.
I agree, that would be ideal. Being new to the area, I do not know anyone. Anyone out there that lives close to the Four Corners area and has nothing better to do give me a holler.
Why not just clamp the square of the torque wrench (where the sockets attach) in a vise, and hang weights from the grip? Torque = force x distance, and both are known, if you measure the distance from the center of the square to the grip pivot.
Dennis K [name deleted for privacy due to age of posting]
- San Antonio, TX
Above statement may not be feasible.
You could also find a place that could do the calibration by doing a google search or maybe the manufacturer could check it for you. I've heard of even Snap-on's being calibrated incorrectly. I think it's mostly torque wrenches for inch pounds that get uncalibrated more frequently.
