Pre-trip CDL weirdness
Kansas
So last trip out I couldn't get the CDL to light up on the dash. Which means no lockers. Getting ready for an upcoming trip I wanted to track down the issue. Using @george_tlc write-up and a few threads on here I began the diagnosis.
-First push CDL button and listen for relay clicking behind dash ( check )
-Second, have someone else push CDL while I listen for whirring noise near TC ( check )
-Third, jump the connector from the switch at the 11 o'clock position on the TC ( here's where the weirdness begins ) even without the CDL button pushed in, its now lit up on the dash.
So I decided to try and replace the switch anyhow. Ordered one off of Amazon and popped it in earlier today, still nothing ! Not sure what to try from here.
Make sure the new sensor/switch (I assume that's what you purchased) is actually working.
Use a meter to test on ohms range. With the sensor/switch out of the vehicle, measure the resistance, should be essentially open circuit without the end pressed in. Then press & hold the end in with your finger (or push it down onto the bench) while using the meter to measure the resistance - it should be near 0 ohms (depending on your meter's test lead resistance).
cheers,
george.
cheers,
george.
I will give it a shot tomorrow when I'm back where my voltmeter is. The one that came out was testing at 120ohms when I pulled it the other day. I cleaned the contacts and ran some current through with three 9 volts in series. That got it down to 50 ohms but still not working, which is when I ordered the new one. What's your suggestion if the new one checks out on the voltmeter ?
Check the new with the meter (should be close to zero ohms when the plunger is pushed all the way in). I'd then hook it up to the vehicle (don't bother to bolt in in - just connect it to the harness/connector). Then press it in and ensure the CDL light illuminates reliable with each push in and goes out with each release.
cheers,
george.
CDL hack to store in your head - IF your CDL will not lock (bad actuator or?) you can put a jumper on the center differential lock indicator switch and the CDL will light up and you will have F & R lockers. You still will not have CDL but you will have F & R lockers and that should get you off the trail.
Not weird at all. The indicator circuit in completely independent of the actuator and its electronics.
Good to know. I was going to test that theory out on my red one tomorrow. All the write-ups I have seen say jump the connector then go push your CDL button. So if the new switch checks out on the voltmeter does anyone have ideas where to look next ?
Agreed. Jumping the two wires to the switch should light up the CDL light, and activate power to your FR & RR lockers.
Have you verified the CDL is engaging fully?
You've said you here the actuator whirring, but if the CDL is not fully engaged, the switch won't be depressed fully, so no light on the dash.
Try jacking one wheel off the ground, hit the CDL button, rotate jacked wheel until you hear the CDL positively click into the locked position. Once locked, you won't be able to keep rotating the lifted wheel.
I had an actuator fail (actually, I fried it. Oops! ) One of the motor windings had a dead short. On the bench, the actuator worked, in the car, the actuator would start to move, but stall out due to the shorted winding.
@mudgudgeon i'm starting to lean that way. Today I took a know working switch and put it in the 97 to no effect. My next test will be to depress the switch while its hooked up to the connector and see if the lights come up on the dash. If so then I reason its the actuator itself. Not sure if there's anything on troubleshooting or repairing those.
You're on the right track here. Verify the switch in the harness.
If that works, test the CDL with the truck moving, make some turns, figure 8's, etc. If the splines aren't lined up the collar won't slide over, the locker won't engage, and the light won't come on. mudgudgeon suggested a good way to test that as well.
Unfortunately, the collar might be moving enough to engage the locker, but not quite far enough to trip the switch. Then you're gonna have to dig into that. Highly unlikely scenario, though. Most likely the splines just aren't lined up.
Dumb question: are you sure you replaced the correct sensor? There are three within inches of each other.
The one I replaced is the one that lights off the dash when you jump it.
@-Spike- I had thought maybe things weren't lining up. While running trails in Arkansas the other day I must have pushed the button a hundred times. I will give it one more shot doing some figure 8's out in a field. I also thought about banging on it with a bar while someone else hits the switch. If none of that works I will look at pulling the actuator.
