I am sure people would buy these if they could, but I don’t know how you would ship them to the US.in our city, they sell this fuel tank from prado 120 for $150, Almaty, Kazakhstan.
just pack in a box and send, we can send up to 14kg/30.6 lbs through a standard post office.I am sure people would buy these if they could, but I don’t know how you would ship them to the US.
I am still trying to find these two parts - the wiring harness and the fuel tube grommet
what is the part number of this wiring and pipe attachment?I am sure people would buy these if they could, but I don’t know how you would ship them to the US.
I was assuming shipping would be restricted because they contain(ed) fuel unless the tank was thoroughly cleaned out. I don’t think you could ship via air and can’t ship overseas via ground, the only other option would be by boat. I am basing this on what is restricted for shipping in the USA.just pack in a box and send, we can send up to 14kg/30.6 lbs through a standard post office.
by air delivery, by plane. I think the post office will allow delivery if I wash the fuel tank.I was assuming shipping would be restricted because they contain(ed) fuel unless the tank was thoroughly cleaned out. I don’t think you could ship via air and can’t ship overseas via ground, the only other option would be by boat. I am basing this on what is restricted for shipping in the USA.
82165-60170 “wire, frame, no.2”
77295-60260 “grommet, fuel tube”
New parts:
77295-60260 25$
8216560170 58$
delivery about a month to my city.
| Sub Tank | Qty | Comment | |
| Tank | 77001-60641 | 1 | |
| PLUG(FOR FUEL SUB-TANK) | 90105-12116 | 0 | come with tank |
| GASKET(FOR FUEL SUB-TANK) | 90430-12245 | 0 | come with tank |
| PROTECTOR, FUEL TANK, NO.2 | 77606-60140 | 0 | will fab a skid plate |
| BOLT, W/WASHER | 90119-08A33 | 5 | |
| BAND SUB-ASSY, FUEL TANK | 77601-60270 | 2 | |
| BOLT, W/WASHER | 2 | NLA - ordered 90119-10816 instead | |
| BOLT, W/WASHER | 90119-10816 | 2 | |
| CUSHION, FUEL TANK, NO.1 | 77651-26070 | 0 | these come pre-installed on tank |
| Sub Tank vent | |||
| TUBE SUB-ASSY, FUEL EVAPORATION, NO.1 | 77026-60150 | 1 | |
| GASKET, FUEL SUCTION TUBE SET, NO.1 | 77179-26010 | 0 | comes with tube sub-assy |
| VALVE ASSY, FUEL CUT OFF | 77380-26010 | 1 | |
| SCREW, W/WASHER | 93319-A4010 | 4 | |
| Sub tank fuel line/ vent | |||
| TUBE SUB-ASSY, FUEL TANK VEN | 77017-60460 | 1 | |
| GASKET (FOR FUEL TANK SUCTION TUBE) | 77169-14010 | 0 | comes with tube sub-assy |
| GROMMET, FUEL TUBE | 77295-60260 | 0 | NLA |
| SCREW, W/WASHER | 90159-50219 | 7 | |
| Inlet Piping | |||
| PIPE SUB-ASSY, FUEL TANK INLET | 77201-60840 | 1 | |
| PIPE SUB-ASSY, FUEL TANK FILLER, LOWER | 77011-60140 | 1 | |
| GASKET, FUEL TANK FILLER PIPE, LOWER | 77178-34010 | 0 | comes with tank filler, lower |
| SCREW, W/WASHER | 90159-50219 | 8 | |
| HOSE, FUEL, NO.2(FOR FUEL TANK INLET PIPE) | 95313-13020 | 1 | |
| CLAMP | 90460-22001 | 2 | |
| HOSE, FUEL TANK SUB INLET | 77213-60240 | 1 | |
| CLAMP (FOR FUEL FILLER PIPE) | 90460-46005 | 2 | |
| main tank filler hose | 77213-35380 | 1 | |
| filler hose clamp | 90460-46006 | 1 | |
| filler hose clamp | 90460-55003 | 1 | |
| Main tank mods | |||
| TUBE SUB-ASSY, FUEL MAIN, NO.2 | 77206-60290 | 1 | |
| CLIP, TUBE JOINT | 77241-60320 | 3 | |
| TUBE ASSY, FUEL SUCTION W/PUMP & GAGE | 77020-60212 | 1 | |
| GASKET, FUEL SUCTION TUBE SET | 77169-30050 | 1 | |
| Tube diagram | |||
| TUBE, FUEL TANK TO CANISTER, NO.2 | 77019-60040 | 0 | wont use |
| TUBE SUB-ASSY, BREATHER | 77012-60120 | 0 | wont use |
| TUBE, FUEL RETURN, NO.1 | 77208-60140 | 1 | |
| CLAMP | 96132-51100 | 6 | fit evap fitting on sub tank, fuel vent from main tank (1/4") |
| CLAMP OR CLIP(FOR AIR HOSE, NO.2) | 96132-51300 | 2 | fuel feed |
| CLIP, FUEL HOSE | 90959-04001 | 2 | fuel return |
| Electrical | |||
| GAGE ASSY, FUEL SENDER | 83320-60460 | 1 | |
| SCREW, W/WASHER | 93319-A4010 | 5 | |
| WIRE, FRAME, NO.2 | 82165-60170 | 0 | NLA |
| Alternate wire harness - from 200 | 82163-60410 | 1 | (no ground connect) |
| Extra Clamps | |||
| evap to engine hose clamps 10mm | 96132-51300 | 4 | |
| 3/4" constant tension clamps | 90467-21010 | 6 |
I hate to say it, but based on my experience doing it first time you’ll probably want to budget the rig being down for 5 days minimum. Depends if you need partsnlocal or parts shipped. Probably only one non weekend day if parts locally available.
