Power Sterring pump/Gears...
Has anyone ever had a issue with they're PS pump gears?
I recently had a shop replace my pump a couple months ago because it was starting to seep, Immediately after i got it back i noticed a new noise that wasn't there before,, at first it sounded like it was coming from the valve cover (area) but after further inspection you can definitely hear it most noticeable at the pump and even feel it strongest if you put a bar on it. I was out of town at the time and washtub traveling for a few weeks or else i would of brought it back to the shop right away, i also supplied the part to the shop so...
Since the pump is what i replaced i automatically assumed it was the pump so i re built the old one and had it swapped back out (different shop this time), The noise is still there of course. But this mechanic who just swapped out this one said it almost looked like somebody used channel locks or something on the gear to hold it in place possible to get the nut off so it got a bit mangled.
At this point i'm not happy having to go in there for a third time,, at least this shop is being cool and is offering to swap the gear out for free because they feel bad giving it back to me not 100% I hope replacing the gear this solves the issue!
Yup if you nick the teeth you will create noise , I use impact and hold the gear with my hand using thick leather gloves, then pressed it off, put it back on by smacking with rubber mallet then impact back on which will set it into place
Thanks guys i appreciate the feedback! This definitely sounds like the issue! Do you think its going to affect it ( make it worse or do more damage) if a drive it over the weekend ? Definitely not wheeling it or anything like that but i have to drive it back to the shop on Monday and wanted to do some other work on it over the weekend so no choice but to drive it...
You can make a simple tool to hold that gear so you don't damage it's teeth, here are some photo's of what i made out of a wood 2X6.
img_9947-jpg.1291949
img_9946-jpg.1291948
img_9948-jpg.1291950
I've also read that when you put the gear back on its important to make sure the gear gets pressed back onto the pump shaft the same amount as it was before or I will make noise.
I don't press the gear on I do it just how I said above and have never had problem
Just as an FYI, the shaft on that pump is tapered, and machined for a woodruff key. So when you torque that gears retaining nut down, that taper and torque will determine just how far that gear can go on that shaft.
Well a little update, I had the gear swapped out with a new one and the noise is still there! I was speaking with my buddy and he was saying that there is a good chance that the gear that was nicked or scarred could have now nicked or scarred the gear or gears on the engine side which could turn into a much bigger problem or job to fix. Has anyone had this experience while trying to fix this issue ?
Also I have the old gear and it definitely looks like the mechanic that I had doing the work at that time put a pair of channel locks or something directly on the gear to hold it! I don't understand why anyone would do such a thing?!?! SMH
Here's a couple pics of the old gear that was pulled off, Also after further inspection it looks like the gear seems to be warn down more on the inner teeth which means it may have not been installed 100% flush or torqued down properly!
At the end of the day its my fault for having someone else do a simple job that I could of done because I was in a rush and didn't have the time :bang:
I mean I've always thought it would be cool to have a diesel but theres nothing cool about your 80 sounding like one when you don't actually have one :cool:
Some pics of the old gear
In hindsight, If you want a job done right, you always NEED to do the job yourself.
That's horrifying. Whoever did that shouldn't be claiming the title of "mechanic".
For what it's worth (not much at this point), all I did was make jaw pads out of some old plywood. Worked great.
One additional thought: I wasn't able to get the woodruff key out without scarring it. I ordered a replacement from Toyota. Afterward, I realized that the local hardware store has metric woodruff keys. But here's the thing, I'm not sure if there are JIS woodruff keys. The gear wouldn't seat to the correct depth if a scarred or poorly-fitting woodruff key was used.
@landtank
So the gear was replaced on the pump and the motor still makes noise in the gear area.
