Power steering
Utah
In addition to turning over 250,000 miles, I also got a surprise:
The alternator managed to rub its way through a power steering hose. :crybaby:
Any idea how this happened? The hose isn't touching a belt nor the fan on the alternator.
I guess it's time to replace some hoses.
More pics...
1 - from the top of the engine bay
2 - behind the alternator
The hose is soaked with oil. Between the oil, the heat, the vibration, it doesn't take long to start swelling the hose and causing it to twist. A little is all it needs to start rubbing.
The hose is soaked in oil because it was spraying from the hole in the hose.
I've PM'ed CDan for a price on a new hose, and possibly a new pump.
Lane,
Two observations (after carrying my laptop out to the driveway and comparing :lol:):
1) My alt. is adjusted nowhere near as far out on its bracket as yours.
2) Even if it were, my hoses wouldn't be as close to it as yours are.
Not sure if that's any help, but it is a data point. :meh:
Curtis
That's a pretty useful tip, Curtis....I just so happen to be running aftermarket belts....:o
All the 1FZ guys say you can get new belts for less than $30, but does that apply to a 3FE?
Just did my pump and high pressure hose Tuesday night. Thanks to Dan and Romer for their suggestions in the FAQ. The high pressure host for my '95 80 was about ~$118 if I remember correctly.
Also, there is some foam shielding there but even so, it is a good 3" away from the alternator on my rig.
And lastly, I had good luck removing the hose from the gear box going through the wheel well. Tough to break loose so I gave myself more leverage by looping another wrench on the open end of the socket, if you know that trick.
Paul
Got a new hose installed. That's one less leak I need to worry about.
1 - Old and new
2 & 3 - Find the hole(s)...
4 - Installed. Camera angle makes it look closer to the alternator than it really is.
Maybe a suggestion or tip, but could "tape" the low pressure hose to the high pressure hose so that it leans towards the opposite direction. Had good luck with cloth electrical stretch tape or something, and of coarse duct tape.
I thought about that, but I already put everything back together...
The EXACT same thing happened to me on the way home from New Hampshire on I84 at night. This was quite a few years ago and I was able to tape the hose with electrical tape and put a hose clamp over the wound. That trail fix held for a week. I replaced both low pressure hoses with 3/8" fuel line. I bent the low pressure hard line on the PS box slightly away from the altenator to prevent this from happening again. Never a problem since.
