Power steering pump...multiple failures
San Diego
I have a 1989 HJ61-12HT. The seals on my ps pump started leaking. I took it to my local shop for a rebuild. That rebuild didn't hold. I ordered a rebuilt unit from a known parts house and that unit failed (leaking), too. The parts house replaced the unit and the new unit lasted about 6 months. It has now also failed - not leaking but not pumping fluid.
My local shop is suggesting we replace the Toyota pump with something more common - GM or? Has anyone had any experience changing an LC to a different brand pump?
I appreciate any help/info offered!
Cheers!
Finally!!!! Saginaw PS pump conversion kit for FJ60s!!!!!
The answer to your dreams!
EDIT: oops can’t find the link, will keep looking. 2nd EDIT: can’t get the Search function to work on my device, sorry.
here’s the link, super easy swap and a great upgrade! Good luck
not sure the 2F setup will work on a 12HT??
is new OEM pump not available?
Maybe contact West Texas Off Road for a rebuild.
Of course new would be best but if NLA this place has a good reputation.
Subscribed. I'm watching this thread to see what works for you. I have wondered if the saginaw pump would, or could be modified to work with the 12HT (or in my case, 2H). Please post up if you get something to work.
