I have a '96 LC and what appears to be a new PS pump from the previous owner, yet I'm losing PS fluid. I have to top-off every 2-3 weeks. I recall someone mentioning maybe the seal wasn't replaced. Anyone with info on this, part numbers for a seal, and anyone with a step-by-step on how to replace the seal?
Do a search. Also, be SURE you know where the fluid's coming from. There are several hoses that age and are sources for leaks, and one is heart-stoppingly expensive. Just the kind of thing a PO would do - replace a pump thinking it's a pump issue, then either not realizing it did not fix the actual leak (a hose), or discovering the hose that's been the source of the leak all along is $250. Or, an old dry hose simply is not sealing correctly after it was disturbed by a properly done pump replacement for a leak. In other words, lots of possibilities here but your best course of action is establish POSITIVELY where the leak is coming from.
Nope, on the 1FZ the pump is gear driven, so if the front seal leaks, the fluid goes into the crankcase.
I don't see why someone wouldn't replace the seal, it comes in the kit. All of them that I have done were hard, cracked, junk. IIRC they are only available in the kit, but I wouldn't take the pump apart and reuse the o-rings.
the best way to hunt for leaks is to clean the area well (turpentine works, but I'm sure that a more friendly product also exists)
then put on some safety gear (especially goggles) and get under the rig
have someone turn from stop to stop a few times and shine a light along the hoses to look for a leak.
leaking high pressure hose can be very dangerous.
***DON"T feel around for a leak with your hands. Hyrdraulic fluid coming out of the high pressure side is hot and very high pressure. It could actually inject into your tissue and cause serious damage. There was a link about this somewhere.... gnarly stuff, gangrene on fingers and whatnot. Don't do it.
But do watch from a distance to see where the fluid is escaping. I had a bad high pressure hose that would only leak at full-turn to the left. Not sure why left, but that's where it would shoot a fine jet of fluid. The jet would go all the way back to the rear of the motor and looked like a bad valve cover seal.
I'm still trying to track down my leak. I replaced the Cooler and hoses going to it (Low Pressure). And I'm not losing ATF from the PS as fast as I was, but I still am. Now I looked under there today to see if I see something and it looks wet behind what I think is the PS Pump. Looks like the idler pulley is bolted to the oil pump cover. With the PS Pump behind that on the drivers side.
Having the same issue on my 97 LX450 - this is a new rig to me and the seller disclosed it as a known problem for him and adjusted the price several hundred dollars - I'm going to take it into the local favorite Toy mechanic for repair and have him look over the rig for any other issues he finds. I'll report back to the collective.
Went to check power steering fluid the other day and it was full of bubbles. Looked like gold colored champagne. Found that a bit odd, but I'm a rookie when it comes to auto repairs.
