Hi everybody, once again need your expertise. I ll try to explain briefly
I have purchased the second hand power steering gearbox for my hdj80 1991, the donor vehicule was 1996, with petrol engine. My vehicule is 1991 HDJ 80 turbodiezel
The result of this was heavy steering compared to old one. (with 31" tires) but it was drivable.
now i have purchased the 35" yoko Geolandar, and the steering is too heavy to turn. I read the book and discovered that before 1995 the pression of steering pump was 85kgs/cm2, but after 1995 changed it to 100kgs/cm2
my question = is this a pression probleme? and if yes how can i change the productivity of pump to fix the pression to 100kgs/cm2?
I also know that there is a valve on power steering pump which regulates the pression but i dont know if it can be changd or modified.
ps. the pump worked fine until i changed the gearbox. the gearbox itself is in good condition no leaks, and old owner says it worked fine...the donor vehicul had only 50k miles on it.
I have converted it from RHD to LHD
