power steering playoff....
HeavyLift said:
Yeah its seems that it would be pretty tight in using a Saginaw box. I was just hoping to eliminate a few moving parts.
I think my biggest problem is going to be getting that pump bracket on the B engine. Not sure but is the alternator positioned lower on a B vs a 3B?
Where did the extra pulley come from (the one on the engine)?
and, it appears you bolted that pulley to the previous one?
Hehe so many questions...it will sure be easier once tear into it...just trying to get everything I need prior to my arrival. The cruiser is sitting with my buddy about 6 thousand miles west.
Travis
Extra pully was a last minute thing, we pulled a power steering pump pully and had the centre machined out, then drilled out the holes for the bolts which are already tapped into the harmonic balancer.
You could try and find a proper pully off a 1983 to 87 BJ in Canada.
If memeorey serves the alteranator on the B is the same location is on the 3B.
The picture of the hard line I ran around the front frame rails like the 1983-84 BJ42 did not work out.
What I did was get the entire setup off a donor truck, cut the lines and used standard fittings on the soft and hard lines were they meet.
No source for those metric fittings in my neck of the woods.
Not sure if this will work for the second pulley...any guesses?
http://www.marksoffroad.net/specials/Specials.html
Tim is there a chance I could get you to show me the pics in that magazine and, do you believe that there will be enough room for the pump reservior or are you going to have to have a remote location for that? (you said you were using a saginaw pump right?)
In another thread somebody mentioned use of a bracket placing the pump above the alternator. It was questioned since it probably meant your alternator wouldnt fit on that bracket (newer setup). Thread pretty much stopped there...any new thoughts on that?
Travis
cruiser user said:
Rob, The pully Idea is a good one. I'm trying to locate a 3b pulley also and not having any luck. Do you think the idler pulley is necessary? If so Why? The set up I saw in toyota trails was virtually identical but without the Idler. Tim
Thanks, it was Sunday and I had to improvise with the pully.
Not sure about running it without the pully, I would however mount the bracket up a little higher next time.
We made templates for the bracket that bolts to the engine and the belt number, for reference.
I culd probably trace it on paper and fax you the bracket design.
Robb
Tech tip
Travis- here is the clip from toyota trails, I hope it works, It is the first time I have tried to attach any thing. My computer is ancient. Tim
Hey guys, I will try and get those tracings off to Tim this week.
Heavylift, did not know you were good buds with Matt from FJ45 resto thread...
Heard you are cruising in a duel egg beater over in Iraq, anyhew keep well.
Good luckwith your power steering conversion..
Rob
Suprise !!!!!
Hey , the fed ex guy just knocked on my door and delivered a package. I had called 4 Wheel auto in Edmonton Alberta [wherever that is] to see if they could get me the crank p/s pulley. Kevin said he'd get back to me but never did, so I thought they could'nt find one. So I opened the package and theres my pully and spacer all shiny black bright from Japan! Part #'s as follows 13478-60010 spacer for harmonic balancer, 13477-60030 power steering pulley-on crankshaft. BUt thats not the suprise! This Was------Payment Amount $211.20 ------------
Hope thats Canadian bucks!!!
PS. got to get that MC bill before the little woman sees it. If she does, I'll just promise never to do it again. It's easier to ask for forgiveness than permission........
Rob- haha yeah I know Matt, good sh!t....he is the reason i have the cruiser sickness...after seeing his FJ..worked for him years ago and now just hang out anytime I get back home...
And yeah funny how a chinook looks like two palm trees humping a dumpster huh? Great ride though...wouldnt want anything else...they are all just a sling load ;)
Pulley options??...
Not sure if this pulley would bolt onto the existing pulley? Its an Accesory Drive Pulley, bolt on, Billet Aluminum, fits over existing single-groove harmonic balancers on 64-72 Landcruisers...at least as the add reads...
Tim-If I understand what you purchased correctly - a pulley to bolt on to the existing pulley with a spacer?
BJ- Thats a great looking bracket...and great pics thanks!!...did you create that yourself? haha I want one...
p.s tim haha yeah thats a good pic...i should post a few of the sling loads we have done out here...think i have one of an Apache hanging below the beast!!
Travis
bj42turbo said:
Some further pics and info, I fitted a saginaw pump using a custom made bracket and OEM box on a bj42 but with a 3b
Cheers BJ
QUOTE]
nice job on the bracket... looks like it fits perfect...
Thanks, the bracket I modifyed one that come with the pump but unfortunatly it came of a Locally produced car, Holden (GM) Commodore. I would have to add there was a lot of luck involved. I fitted the pump where it had a air con compressor and was able to use the existing pulley and even the existing belt
BJ
toyota pulley
Travis- I bought a stock toyota pulley that comes on the 83 and later bj42's. It was expensive but when it showed up at my door I decided to keep it. That pulley you show would probably work and I'm sure is less expensive. you might have to drill new holes to match your existing pulley. the guys at 4 wheel auto told me that earlier bj 40's came with just two bolt holes intheir existing crank pulley. If that is the case the pulley I bought from them wont fit anyway. 42's have six tapped bolt holes in their crank pulley.
Good deal
Yeah I think I will have my buddy order that pulley for me and see if it will fit. Guess I will be on the look out for a bracket that might work or work with some modifying. I really like the look of the bracket BJ42 used that came from the Holden.
I have since lost or got rid of those templates, but the guys at Hill Top Cruisers like my design and have made a few of these brackets, try them.
Rob Lassman
