Power steering noise?
Hi guys,
My CA 1980 FJ40 has PS and recently only when starting (from cold) makes a noise when turning the steering wheel. The PS reservoir is full. And the sound seems to disappear after a few minutes and does not return. Any suggestions what I can check? The sound seems to be only when cold and you turn the steering wheel. You can also feel something in the steering wheel during the sound. Any thoughts greatly welcomed. Many thanks, Ed
more screeching but I am pretty sure not fan belt. Anywhere I should explore? thanks Ed
I was a bonehead and checked wrong resovoir. I noticed PS resovier was LOW. Looks like red ATF. I will get some new ATF dextron and fill. I can only find Dexron III here I the UK. Is that the same as “normal” dexron? Hopefully that removes problem. The sound was low pitched screetch ONLY when steering wheel moved from center to turn. Fingers crossed That sorts it. Best, Ed
