Power Steering Gearbox Issue
Oklahoma
Fair warning, I'm a dumb college kid and not a great mechanic. So a few months back I had a reputable mechanic install a certified refurbished gearbox. Earlier today, I was turning into my neighborhood when all of a sudden, turning the wheel sounds atrocious and it was clear something broke.
I look under the car and see tons of power steering fluid caked under the car and also dripping. Is this gearbox toast? Is this just a seal or something that caused oil to drain? Thanks for the help!
Sounds like you’ll be buying a new power steering pump if you keep running the engine without fluid in the steering system. It’s doubtful the steering box puked fluid that rapidly. You will probably find a hose that has burst or come disconnected.
Don’t run the car anymore, noted. I tried looking for a hose that was burst open or broken but oddly enough couldn’t find anything. It felt like it happened so suddenly when driving but when I put some PS fluid in the reservoir, it didn’t instantly fall out anywhere and was just a slow drip but I couldn’t identify the source.
I’ll attempt to investigate more today
i mean did you look at it? or check the rezzie to see if theres fluid?
Yeah the gearbox itself looked normal from what I could tell just looking at it from under and the reservoir was empty. Maybe a hose somewhere that I missed
Look closely at the rear of the pump.
the rear seal on mine went while I was in the store and I came back out to see it literally running out like a faucet. I drove it 2 miles home and replaced it the next weekend. Looks like you'll be doing the same soon.
You could just rebuild it if you wanted. There's a few great threads on how to do it here if you search. Its not hard and not even very expensive
...because there's a plug that can pop out, emptying all the fluid quickly. More common in rebuilt pumps.
And also the rear cover can pop off. This happened on a pump that I resealed a few years ago. Luckily it popped off in my driveway the day I installed the pump.
Installing the rear cover is a SOB, however, I was sure that the snap ring was fully installed into the grove when I was finished. If my memory serves me, that snap ring has a round cross section.
